Quantcast Which size quicker disco's for REBB? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Which size quicker disco's for REBB?
Old 09-22-2006, 10:37 AM   #1
ROUGHSHOD
I am about to buy a set of JKS Quicker Disco's and wanted to know if the 0"-2" size would fit correctly with a REBB (spacers + OEM spring isolator pads). The next size is for 2.5" and up which I was thinking might cause a problem when trying to get into the right angle for the swaybar. I have no plans on going higher for at least a couple years. I'm probably splitting hairs, I know, but the D@#N perfectionist part of me just won't quit.
ROUGHSHOD is offline   Reply With Quote
Old 09-22-2006, 10:47 AM   #2
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
I have 0-2" JKS disconnects with 2 " spacers....they work fine....you can adjust the disconnects for the height you need.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline   Reply With Quote
Old 09-22-2006, 11:28 AM   #3
Lud04X
I got the RE Gen II quick discos from 2.5 and up and they work fine for my 1.75 inch lift with no problems with the swaybar at all. Plus when you go bigger you can resuse them!! Try the 2.5" and up.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline   Reply With Quote
Old 09-22-2006, 11:39 AM   #4
ASUsax
That would be the big upside to a more universal disco, the ability to re-use them as your Jeep grows up.
Blue Jeep Club Member #197
'02 TJ - 31" BFG AT's, some armor, yadda yadda. 2" BDS lift.
'94 ZJ - May it rest in pieces.
ASUsax is offline   Reply With Quote
Old 09-22-2006, 11:43 AM   #5
TXST8tj
you can use the 2.5" and up discos just fine with only the RE BB. for the same cost, you might as well get the ones that you can keep as you grow. no sense buying them twice.
Patrick
Build Thread
Goodyear-Corbeau-Hella-DDM Tuning-Alpine-Kicker-JL Audio-Tuffy-KC-Bestop-Firestick-Cobra-Skinny Pedal-Rough Country
TXST8tj is offline   Reply With Quote
Old 09-23-2006, 07:44 AM   #6
davenjeip
Go for the bigger ones.
They have plenty of adjustment in them to work properly with a BB and will still work if you go bigger.
2003 TJ
1967 M715
[URL=http://www.davenjeip.com][b][color=red]www.davenjeip.com[/color][/b][/URL]
davenjeip is offline   Reply With Quote
Old 09-23-2006, 08:36 AM   #7
CNY
x3 on getting the bigger ones. You'll have no problems.
CNY is offline   Reply With Quote
Old 09-25-2006, 01:24 PM   #8
tjchad
I put the 2.5 - 6" JKS Quickers on with my 2" lift and have had zero problems. I figured I don't want to buy bigger later...
Chad- KI6BIG
'02 SportD442"BB
Pics: [url]http://smg.photobucket.com/albums/v234/tjchad/[/url]
tjchad is offline   Reply With Quote
Glock Forum
