Simple request for you TJ guys regarding gas mileage - JeepForum.com
post #1 of 26 Old 03-01-2014, 01:24 PM Thread Starter
Eckoh
Not 100% sure if this is the right place but i'll post it here
We all know TJs do not get great mileage. However i have found reports that gas with ethanol added will not "agree" as well with the 4.0 engine. So if some of you could just use a few tanks of gas with ethanol and a few without and compare the mileage we might able able to find out if there is any truth to it.
http://pure-gas.org has a listing of gas station that have ethanol free pumps, its not 100% accurate so you might have to double check yourself to see if it is ethanol free.
Please help me figure out if there is any truth to this is emperical date from a number of sources rather then just hearsay.
Eckoh is offline
post #2 of 26 Old 03-01-2014, 01:39 PM
hokahay
Like this?
date gal price cost odometer miles mpg
11/03/12 14.82 3.3189 $49.18 87606 210 14.17
11/17/12 14.82 3.9816 $59.00 87827 221 14.91 rec fuel
12/01/12 13.27 4.0692 $53.99 88038 211 15.90 rec fuel
12/15/12 14.72 3.2588 $47.96 88279 241 16.38
12/29/12 15.17 3.9788 $60.37 88505 226 14.89 rec fuel
01/15/13 15.01 3.3889 $50.85 88756 251 16.73
01/28/13 14.6 3.4189 $49.93 88983 227 15.54
02/15/13 14.72 3.7392 $55.03 89203 220 14.95
02/24/13 14.82 4.4692 $66.22 89410 207 13.97 rec fuel
03/14/13 14.4 3.7410 $53.87 89632 222 15.42
03/30/13 15.12 4.3693 $66.05 89845 213 14.09 rec fuel
04/12/13 13.4 3.5385 $47.43 90064 219 16.34
This is a log of fill ups and the type of gas either 87 ethanol or rec fuel. The resulting mileage for the fuel type shows in the next fill up.
I think it is obvious from this data that there is more energy per unit volume in the rec fuel.
hokahay is offline
post #3 of 26 Old 03-01-2014, 01:47 PM Thread Starter
Eckoh
yeah that kind of data
It looks like more then a 1 MPG increase with the non ethanol fuel. That is just one source of data as well
Eckoh is offline
post #4 of 26 Old 03-01-2014, 01:53 PM
hokahay
While the MPGs were better the Miles/$ were worse lol. I also wonder about engine life between the two fuels while you are at it.
hokahay is offline
post #5 of 26 Old 03-01-2014, 03:30 PM Thread Starter
Eckoh
prices vairy place to place, where i am the prices are the same just the "brand" is different.
Eckoh is offline
post #6 of 26 Old 03-01-2014, 03:56 PM
JealousDad
I must be reading it wrong. It looks like your worst mileage (13.97) was on the rec fuel and the best (16.73) was on the ethanol fuel. And the rest of them aren't that far apart.
JealousDad is offline
post #7 of 26 Old 03-01-2014, 04:10 PM
Dave02TJ
In Illinois we don't have the option to buy non ethanol fuel. E10 was here in 80's and has been ever since. I should say that yes, you could buy racing fuel at some obscure station at an outrageous price that wouldn't have ethanol.
Anyways...The engine life seems to be fine, 200,000 miles is obtainable on many vehicles and could be surpassed.
Rust is the bigger worry here.
Dave02TJ is offline
post #8 of 26 Old 03-01-2014, 04:11 PM
hokahay
The line that is marked rec fuel is the kind of fuel purchased that day. The mileage for that purchase shows at the next fill up. That is the next line.
Where I am the price for 'real gas' is much higher that for the ethanol blend. If it was the same I'd never buy ethanol. The pump is labeled "for recreational use only' but I figure if my TJ isn't recreation what the hell is! Sure as heck isn't my lawn mower.
hokahay is offline
post #9 of 26 Old 03-01-2014, 04:11 PM
Dave02TJ
The fuel burned after the REC fill up is the non ethanol. So when you see REC the mileage of that fuel is calculated at the next fill.
Dave02TJ is offline
post #10 of 26 Old 03-01-2014, 04:19 PM
hokahay
Correct. I have kept a record of every single tank like that since I bought the jeep in September 2004. 390 fill ups. 4911.966 gallons. $14306.14 and 77,435 miles. 15.76 mpg. $2.91/gal.
hokahay is offline
post #11 of 26 Old 03-01-2014, 04:23 PM
Dave02TJ
Holy cow, I'm glad I didn't keep records! I calculate the MPG's at fill up but don't keep records. HOLY COW $14,306.
Dave02TJ is offline
post #12 of 26 Old 03-01-2014, 04:28 PM
JBTJ
I checked my MPG's once that was 148K/13 years ago.
JBTJ is offline
post #13 of 26 Old 03-01-2014, 04:30 PM
hokahay
I am obviously a glutton for punishment. I am also a software engineer. But then I repeat myself.
hokahay is offline
post #14 of 26 Old 03-01-2014, 04:38 PM
glwood6
Non-ethanol in my city is only available at one station I have found. They usually only have it available in the mid-grade octane, and it is about 50 cents more per gallon than regular around here. I have tried a couple of tankfuls, but have not seen a noticeable improvement in mpg.
2012 JK sold. Currently 2004 TJ Rubicon.
glwood6 is offline
post #15 of 26 Old 03-01-2014, 05:02 PM
pcwolf
Ethanol has less energy chemically per volume than gasoline. Science.
-Phil
Man out standing in his field
o|||||||o
pcwolf is offline
