Signs of a Bad Coil? - JeepForum.com
post #1 of 8 Old 07-25-2007, 12:23 PM Thread Starter
gtospeeding
Is it true that the coil will either work or it wont?
what kinda symptoms does a bad coil have other than the jeep wont start?
I have a 98 4.0 with 110k
gtospeeding is offline
post #2 of 8 Old 07-25-2007, 12:31 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
When mine was on its way out it was much more sensitive to moisture.
Are you having a no spark symptom?
Wheelin98TJ is offline
post #3 of 8 Old 07-25-2007, 12:35 PM
EvilM0nkey
EvilM0nkey's Avatar
that's right. There usually isn't much in between. Try putting a screwdriver in one of your wires and lay the shaft near a piece of metal and have a friend try to crank it to see if you have a spark (don't touch the screwdriver unless your into that type of thing...)
EvilM0nkey is offline
post #4 of 8 Old 07-25-2007, 12:40 PM
mdm
Farm Wheeler
A bad coil can show symptoms like loss of power after the engine/coil gets hot, high humidity, high RPMs,...
mdm is offline
post #5 of 8 Old 07-25-2007, 12:42 PM Thread Starter
gtospeeding
on cold starts the starter will crank longer before the Jeep fires. I was thinking its coil related since it looks like the coil is original
BTW --was the coil rivited or bolted to the coil bracket from the factory?
post #6 of 8 Old 07-25-2007, 12:45 PM
mdm
Farm Wheeler
Does the engine start OK after the initial start-up when it has been shut down for just a short time?
mdm is offline
post #7 of 8 Old 07-25-2007, 12:47 PM Thread Starter
gtospeeding
it starts better after its been running but not 100%
post #8 of 8 Old 07-25-2007, 02:05 PM
Wheelin98TJ
JEEP FREAK
Bolted.
IIRC, you have to unbolt the bracket first and then you can unbolt the coil.
Long crank times at cold starts is more often caused by a faulty anti-drainback valve. Its a pretty common problem with TJs.
Tranny Fluid, Signs that its low? jagarcia82 YJ Wrangler Technical Forum 5 02-10-2010 05:57 PM
Some favorite trail signs Joe Dillard YJ Wrangler Technical Forum 6 01-29-2008 09:05 PM
Signs of worn u-joints ? hogzilla YJ Wrangler Technical Forum 1 07-31-2007 05:15 PM
Signs that shocks are worn out UTWeezul TJ Wrangler Technical Forum 12 03-28-2007 12:20 AM
signs of a bad D30 u-joint BigWaylon TJ Wrangler Technical Forum 3 06-29-2004 07:05 PM
