signal light goes on when I brake - JeepForum.com
post #1 of 10 Old 02-23-2005, 11:59 PM Thread Starter
Decz
My left turn signal light goes on whenever I brake (both the dash light and the exterior lights). This only happens when I brake ( 9 out of 10 times ) and the only time it doesn't happen is when my right turn signal is on.
I'm pulling my hair out over this one! Any Idea's?
99 TJ, 2.5 litre
Thanks!
_Decz
Decz is offline
post #2 of 10 Old 02-24-2005, 12:00 AM
DLoweinc
DLoweinc's Avatar
did your dash get wet? usually that happens when the dash is wet
98 Grand Cherokee... Jack Stands, no front axle... Working seat belts!
DLoweinc is offline
post #3 of 10 Old 02-24-2005, 12:04 AM Thread Starter
Decz
Nope, the dash didnt get wet. We have the usual floor flood when it rains, but it's been a month since that happened, and this signal light thing has only been going on for 2-3 days now.
Decz is offline
post #4 of 10 Old 02-24-2005, 12:09 AM
DLoweinc
DLoweinc's Avatar
wish i had an answer for you, my friends TJ does the same thing and the dealer has no idea
DLoweinc is offline
post #5 of 10 Old 02-24-2005, 12:51 AM
wayoflife
LOL, is it your left signal that goes on? mine does that to and finally figured out that the lever gets a little sticky when returning to center. the next time that happens, just push up on the lever a bit and it should go away
wayoflife is offline
post #6 of 10 Old 02-24-2005, 02:39 AM
Av Native
Check to see if you have the correct bulb in there, The wrong bulb could cause feedback thru the system
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline
post #7 of 10 Old 02-24-2005, 05:33 AM
Chipper
Chipper's Avatar
There's a thread posted in here titled "Jeep is Ill", which describes kinda the same problem I had this week.
I would put my left flasher on and the dash light and fog lights would flash on and off.
It turned out to be the flasher socket which was all corroded inside, causing a short.
I suggest you look at each one of the flashers, starting with the front. Just reach up under the fenders and turn the socket 90...it should come out. Pull out the lightbulb and check the four little wire contacts, if they're screwed up, then that's your problem. If not, check out the contacts in the socket for crud. Do the other front flasher and the back ones too. If you have any doubts about the bulbs, change 'em....they're cheap.
Let us know how it works out.
Chip
2000 TJ...Almost stock
Quick Discos and MT/R's.
Chipper is offline
post #8 of 10 Old 02-24-2005, 06:03 AM
endo
endo's Avatar
Me Too
Mine does that as well.
Its the left one I am betting. Like someone else said just jiggle the lever a bit and it will work as it should it has an issue returing to center sometimes.
endo is offline
post #9 of 10 Old 02-24-2005, 06:05 AM
blacksheep1
another thing to check is your grounds. you stated that the floor has been flooded occasionally, think boat trailer here. if your plugs, and or grounding points for the lights became submerged they could have corroded over time and caused the problem to show up now vs right after being submerged. inadequate or nonexistent grounds have been known to cause some very odd symptoms. good luck!
3 Jeep family again.
MINE 1999 TJ sport, HERS 2004 KJ Renegade and 2005 Rubicon
Wind Tunnel Tested . . . FAILED
blacksheep1 is offline
post #10 of 10 Old 02-24-2005, 06:20 AM
emcee5000
emcee5000's Avatar
As previously posted, if it is the left turn signal that stays on it is a sticky lever. A simple giggle is all it needs.
emcee5000 is online now
brake/signal light wiring problems JIBTEXHNKA YJ Wrangler Technical Forum 3 11-25-2009 07:59 PM
RT Turn Signal/Brake light tjtone TJ Wrangler Technical Forum 2 03-30-2007 12:27 PM
Turn Signal and Brake Light Jeep_Grrl TJ Wrangler Technical Forum 8 08-13-2005 03:24 PM
Brake light/signal issues ClarkAM1 TJ Wrangler Technical Forum 3 04-11-2005 11:18 AM
No Brake and signal light ayadov YJ Wrangler Technical Forum 2 05-26-2002 09:58 AM
