Sigh....Transmission issues. Need some help! (will it END ALREADY?)
| Introducing MONSTALINER UV Permanent DIY Roll On Bed Line | TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series |
#1 | |
Ok. In the past month I have posted a number of posts getting to the bottom of issues. Thanks to all of your help, experience and advice I successfully have solved ALL my issues with my engine and everything else. Thanks for that.
Now that the other issues are solved I have one last one: The transmission. I know that the shift points suck in the automatic. I have always thought that. but lately it has been shifting rough! if you are barely pressing the pedal goin 20 it jumps a little. between the speeds of 40-60 (usually when the OD gear kicks in) I get a SLIGHT driveline vibe on and off due to the low rpms. it wants to sit at 1500 rpms and the trans is like begging to down shift but it doesnt. I dont want to have to use the OD-OFF button all the time. I have 33k miles. I have it scheduled for a service at the local dealership next moday. they are also getting a transmission tech to look into it. I WANT them to find something wrong because if they come back and say "well it all looks normal! your good to go!" Im gonna be pissed. What is your experience with this? ![]()
#2 |
Filter needs changed?
Matt 2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat 1981 DeLorean DMC-12 VIN: 2953 |
#3 |
Its still under warrenty and if you get it doccumented and its still not 100% just keep taking it back. You may have to try a different dealer and if you get no help call D.C.
2000 Sport. |
#4 |
that's just how my tranny as well (04 4spd). I use the OD Off button but it's a bit of a hassle as well. there are ways you can try to reset the shift points by cutting power but the fact remains that this tranny always shifts way too early and vibes at 40-50mph.
2004 Yellow TJ Sport
(purchased stock on 6.3.06) PICTURE 4.0L Auto 35" Maxxis Bighorns D30/D44 w 4.88 Gears 2.5" OME LJ/XJ lift JKS Trackbars Brown Dog MML 1" BL Warn Engine Skid Aussie Locker (FR) / Rubi Air Locker (REAR) SYE/CV Nth Adj Control Arms Bestop Oversize Tire Carrier PSC Rocker Knockers ORO Swayloc TNT Tube Fenders MIDSOUTH JEEP CLUB > Jeepers from TN, AR, MS, and KY |
#5 | |
Its getting to the point where I'd rather take my girls grand cherokee than the LJ when we go places on the weekend because it isnt such a aggrivating ordeal to drive. Man they better find something..... BTW there is no filter in my year's trans. (I was told by the dealer.) they just drop the pan and reseal it... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
