Side-mount tire - JeepForum.com
post #1 of 7 Old 03-30-2008, 09:52 AM Thread Starter
tecumsa
tecumsa's Avatar
2016 JK Wrangler
Side-mount tire
Does anyone know of a mount I can use to carry my spare on the side of the Jeep? (Similar to image below)
Also, any pros / cons to doing this?
I am looking at this as a method of opening up space on the rear of my TJ to carry a Jerry can or two.
tecumsa is offline
post #2 of 7 Old 03-30-2008, 10:11 AM
robncar
robncar's Avatar
I think I'd end up getting hung up on a side mount. There are tire carrier bumpers that also have Jerry can mounts, I think I'd go that way.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 7 Old 03-30-2008, 11:02 AM
stoker
I had a side mounted spare on a CJ. It was constantly in the way or hung up on trees. That was a bikini only no door Jeep. I moved the spare onto the drivers side of the roll bar with most of the weight resting on the tub rail. This got it up higher and mostly in the Jeep which ended the hangups and corrected the blind spot off my starboard stern.
02 Sport walnut shift knob, H2 reco sticker, rubber floor mats.
stoker is offline
post #4 of 7 Old 03-30-2008, 11:34 AM
rubiweeler
You could order one of the cj mounts and bolt it up to the tub. I wouldn't do it though because they hang up on stuff too much.
You should get or build a tire carrier that also has jerry can mounts.
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline
post #5 of 7 Old 03-30-2008, 01:21 PM
rustym38a1
rustym38a1's Avatar
1953 M-38
Spare tire mounts are still available for the old CJ's. You will need to match the bolt pattern 4 1/2" on 5! But if you do go through with it, you better make sure that you re-enforce the heck out of the inside of your quarter panel or you will peel it off with the first hard bump!
11 Wrangler Rubicon JK 'Call of Duty Black Ops Edition' 2 Door, 6 spd with Magnaflo exhaust, Banks Air intake, 34" Nitto Terra Grapplers
08 Liberty Limited KK- Sky Slider -Every option available at time (wife's car)
04 Sahara TJ- OME suspension, Borla Exhaust, Rusty's Skids, K&N, LED's, Pro Comp 31's
97 Wrangler SE TJ- This is our Trail Jeep. Yukon 4.88's, Powertrax Locker, 32" BFG KM2 tires, XRC/8 winch
53 Willys M38a1- Restored w/50cal Browning M2HB & 53 M100 1/4 ton Trailer fully loaded with gear!
13 Grand Cherokee Laredo WK2- company car
rustym38a1 is offline
post #6 of 7 Old 03-30-2008, 02:34 PM
BlueFlame
BlueFlame's Avatar
-not only that but unless its a teenie tiny tire and even then mounted really high up, it won't clear the rear flare.
Just hold your spare up there and look - you'll quicly see why no one does this.
BlueFlame is offline
post #7 of 7 Old 03-30-2008, 06:59 PM Thread Starter
tecumsa
tecumsa's Avatar
2016 JK Wrangler
OK, Rusty and BF, that's what I was looking for.
I'm just considering options. The auxiliary bumpers won't work because they tend to be model specific, and I'm not sure how much longer this TJ has. I've been looking for a more generic solution.
tecumsa is offline
Frame mount vs. Body mount tire carrier mrbillbrown TJ Wrangler Technical Forum 9 05-11-2009 06:22 PM
Side mount spare tire carrier? superbee70 YJ Wrangler Technical Forum 12 12-18-2008 07:15 PM
31" Tire on stock tire mount rubber stop question? Diablosjeep TJ Wrangler Technical Forum 8 04-04-2008 08:02 PM
Plans for Modifying rear tire mount to fit 33" tire BADEAGLE TJ Wrangler Technical Forum 10 11-02-2006 11:01 AM
body mount vs bumper mount tire carrier cincytj TJ Wrangler Technical Forum 1 07-29-2005 01:02 PM
