Side Mirrors withour doors - JeepForum.com
post #1 of 22 Old 05-06-2005, 01:23 PM Thread Starter
DetroitDoorless
This is my first year with my Jeep. I want to take my doors off and be legal at the same time. I know they make mirrors that sit inside the door hinges. They also make the relocation kit to mount the mirrors to the windshield. Any opinions as to which is better?
DetroitDoorless is offline
post #2 of 22 Old 05-06-2005, 01:26 PM
RubiconSS
RubiconSS's Avatar
Lot of horror stories about stripping out the torx bolts on the windshield.
'05 Rubicon (to go) '01 CamaroSS(to go fast)
RubiconSS is offline
post #3 of 22 Old 05-06-2005, 01:29 PM
rhinoss
I have the mirror relocators and they work great. I'm extremely happy with them. I like being able to use the stock mirrors. They're larger than most hinge mounted mirrors and still appear close to stock.
You can also quickly throw on the doors without having to remove the mirrors if you have the relocators.
rhinoss is offline
post #4 of 22 Old 05-06-2005, 01:37 PM
truckie453
truckie453's Avatar
I have the CJ style relocators...
Love them, easy install but they shake like all heck.
HTH
-truckie
Green Jeep #99
Firefighting Jeep #1
Sometimes the things that may or may not be true are the things a man needs to believe in the most. That people are basically good; that honor, courage, and virtue mean everything; that power and money mean nothing; that good always triumphs over evil, that true love never dies. Doesn't matter if it's true or not. You see, a man should believe in those things, because those are the things worth believing in.
truckie453 is offline
post #5 of 22 Old 05-06-2005, 01:38 PM
NewLaw83
i have the mirrors that you put on the hinges and they work great for me it takes a minute to put them on and off. I got those because i heard the some ppl have problems with their relocation mirrors. When you open up your door as wide as possible the door would knock them out of place.
I got my mirror brackets from Jeepit.com if you are interested.
2004 Red Wrangler Sport
4.0L I-6, OME 2.5" suspension lift, JKS 1.25" body lift, MML, front & rear trackbars, and swaybar discos. 33x13.50" Toyo Open Counntry MT's on AR-767 15x10" rims.
Sam
NewLaw83 is offline
post #6 of 22 Old 05-06-2005, 01:44 PM
RUB1CON
RUB1CON's Avatar
I have the ones from here http://www.jeepit.com they work and look great I got my mirrors from Advance Auto for like 5 or 6 bucks each
'03 Rubicon
RUB1CON is offline
post #7 of 22 Old 05-06-2005, 03:05 PM
jkulbeth
jkulbeth's Avatar
I use long-stem black Harley mirrors. They're a little small, but they offer a great view on the passenger and driver sides, fit like they were designed to go in the hinge, and hardly shake. Check with a Harley dealer and see if they have any removed ones they'll sell for cheap... or eBay. Or, buy them new and spend a lot.
2004 Wrangler Unlimited, Shale Green, soft-top, Shrockwork Rocker Guards, Kumho 31x10.5 AT's
Green Jeep Club Member #119
jkulbeth is offline
post #8 of 22 Old 05-06-2005, 03:48 PM
Spiderman
Spiderman's Avatar
I've got the relocation brackets from SteelHorse, I believe. They work very well, however, be very very careful not to strip out the torx heads like I did on the passenger's side. Anytime you attempt to remove the torx bolts, use a breaker bar and apply constant pressure till they break free.
2001 Sport 4.0L, 5 Speed, Patriot Blue
33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels
4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML
Aussie D30 Locker, & other crap
Spiderman is offline
post #9 of 22 Old 05-06-2005, 04:34 PM
spinnjase
i got a lange 2 mirror and just took the mirrors off of my doors. works great, shakes a fair amount, but i'm sure if i'd get off my butt and put some rubber between the bracket and the windshield frame it'd be fine. they are kinda pricey though, about $60/ mirror. but i wanted to be able to remove it so it didn't get damaged, and down here in LA you just need one. i'll get a passenger side one day....
J
spinnjase is offline
post #10 of 22 Old 05-06-2005, 04:35 PM
davenjeip
davenjeip's Avatar
I got mine shipped NIB for under $30.
2003 TJ
www.davenjeip.com
davenjeip is offline
post #11 of 22 Old 05-06-2005, 04:42 PM
grinwa
grinwa's Avatar
I got mine from PepBoys. I think bigwaylon is the one with the write up. They work pretty good and cost around $30. Easy to install and I can see real well.
Greg
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline
post #12 of 22 Old 05-06-2005, 05:09 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
I like mine. Got them from Jeepit.com.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #13 of 22 Old 05-06-2005, 10:39 PM
JeepGal
JeepGal's Avatar
I have the Rock-itman set on my jeep. Its simple and it works. I can see out of the passenger window. I used cheap AutoZone mirrors. They dont jiggle. I occasionally have to tighten the nut, cause I open my door too far and push them back:P
I think they sell for $12 bucks shipped and powdercoated.
Tam
JeepGal is offline
post #14 of 22 Old 05-07-2005, 05:58 AM
truckie453
truckie453's Avatar
For Milhouse
Milhouse... Pics as requested.
This is the first type (mirror verticle CJ Style)
I have the GEN II (mirror horizontal)
FYI JCWhitney has the convex mirrors that match the orignal head that comes with the kit so you only have to buy the passenger side if you want.
HTH
-truckie
Green Jeep #99
post #15 of 22 Old 05-07-2005, 07:45 AM
FlyguyTKI
For all of you who have to be careful when opening your door b.c they hit the mirror Get a set of 7 dollar shorter straps, they are Perfect.!
FlyguyTKI is offline
Side Mirrors when doors are off, suggestions? KevinInMN YJ Wrangler Technical Forum 24 06-21-2008 04:02 PM
Side Mirrors morganf TJ Wrangler Technical Forum 7 07-20-2007 02:36 PM
Side Mirrors Nivek TJ Wrangler Technical Forum 6 07-12-2006 02:17 PM
Side Mirrors w/ Doors Off? reoterq TJ Wrangler Technical Forum 6 06-09-2006 04:29 PM
where to get side mirrors for when doors r off Jeepthang04 TJ Wrangler Technical Forum 46 03-30-2005 12:13 PM
