Side marker light assembly - JeepForum.com
post #1 of 5 Old 04-15-2008, 07:53 PM Thread Starter
BMdeckie
I am trying to find a bulb housing for the drivers side marker light (the one mounted in the plastic fender). All I am able to find is the lense. The original one is so corroded new bulbs are not able to work.
I have tried JCwhitney, a few other online places, and of course local auto stores.
Would the stealership be the only place?
"Poor planning on your part does not make an emergency on my part."
U.S.C.G. Jeep Club member #2
BMdeckie is offline
post #2 of 5 Old 04-15-2008, 09:29 PM
CDNjeepgrl
if you find this please do post up. mine was ripped off in an accident, so all i have is the wires :S
CDNjeepgrl is offline
post #3 of 5 Old 04-15-2008, 09:44 PM
DixiesCJ3B
I know that on my 99 tj, the lense and the housing are one piece, so the lenses that your finding on this sites, might be the ones that you need, i found mine at a junkyard, best of luck
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline
post #4 of 5 Old 04-16-2008, 06:28 AM
tjmas
2012 WK
I had a 1997 TJ and got the driver side replaced twice in the 2 years I owned it. But I got the wiring with the bulb harness at Chrysler, and I also put in some grease where the bulb goes in to avoid rusting. I thought I saw the wiring harness in quadratec, but it might only be for an CJ or YJ, can't remember.
Now i'm riding in a 2005 and i've already put the grease in again when I changed the lenses to the clears on the front turns and the markers in the flares.
tjmas is offline
post #5 of 5 Old 04-16-2008, 06:29 AM
tjmas
2012 WK
tjmas is offline
Side marker light replacement help needed daryn3g JK Wrangler Technical Forum 7 09-20-2015 09:10 PM
LED side marker light write-up Mean Max YJ Wrangler Technical Forum 38 02-13-2013 06:52 AM
Side marker light help DirtFarmer TJ Wrangler Technical Forum 3 02-09-2010 03:16 PM
Side Marker Light Socket hcreamer YJ Wrangler Technical Forum 3 03-03-2008 10:44 AM
Need OEM replacement side marker light Poseidon17 TJ Wrangler Technical Forum 2 05-02-2005 08:02 PM
