sick little 2.5L - JeepForum.com
post #1 of 13 Old 05-07-2004, 06:52 PM Thread Starter
nsi31
sick little 2.5L
MY '97 2.5L IS RUNNING ME CRAZY......
When it is first started (no matter how many times in a day) even if allowed to run (idle) a while.....once I take off..it coughs, sputter, and generally doesn't want to run.. After a couple of seconds..(and a little "cleaning out" with the throttle, everything is fine. Never a problem until I turn it off..then it starts all over again...
I get no error codes showing any problems...??
nsi31 is offline
post #2 of 13 Old 05-07-2004, 10:06 PM
topless97je
topless97je's Avatar
i have the EXACT same problem....and its just started. it clicks when i turn the key but nothin happens.
could be:
starter solenoid
need tune-up
air filter
fuel filter
i'm planning on checkin on this stuff tomorrow.
i also get code 55.
keep me updated if u find out anything.
Thanx!
and Good luck!
97 Wrangler TJ 2.5L I4 5spd
White Jeep Club Member #70
97 Jeep Club Member #11
My Jeep Pics:
Or..if you're anti-imgstation:
topless97je is offline
post #3 of 13 Old 05-07-2004, 10:10 PM
jeeptoplesstx
jeeptoplesstx's Avatar
catalytic converter....clogged...also check your exhaust manifold for missing bolts/leaks which can add to this...my 2.5 did this allllll the time...I would have to rev the crap out of it....then it would go...
2004 Jeep Wrangler Rubicon
jeeptoplesstx is offline
post #4 of 13 Old 05-07-2004, 10:21 PM
topless97je
nice, i'll look into it tomorrow
thanx
My Jeep Pics:
post #5 of 13 Old 05-07-2004, 10:48 PM
topless97je
at first i thought the battery was the prob...but i just got mine 2mos ago...
My Jeep Pics:
post #6 of 13 Old 05-08-2004, 05:22 AM Thread Starter
nsi31
here is the confusing part....once it is started, and I go through the "ritual", it runs GREAT!! Unless I shut the thing off..everything is fine!!!? If the engine was never turned off...I guess it would be fine forever!!
nsi31 is offline
post #7 of 13 Old 05-12-2004, 06:11 AM
topless97je
hey, it's the starter solenoid
My Jeep Pics:
post #8 of 13 Old 05-13-2004, 08:34 PM
topless97je
good news...problem fixed...$275 later lol (includes alignment)
New starter fixed the prob
My Jeep Pics:
post #9 of 13 Old 05-13-2004, 11:40 PM
jeeptoplesstx
Thats cool...glad you got it all worked out...I just read through the post again and realized that what you were talking about was completely different from the first guy...I would have guessed something with the battery too...well at least you figured out it was the starter before it left you on the side of the road...or trying to push start it...remember to turn the key to on before trying to push start...learned that one the hard way!!! Your new top looks great by the way...what do you think of those silverstars? notice any difference in the lighting?
post #10 of 13 Old 05-14-2004, 06:52 AM
topless97je
oh yea, i just read that again. i'm also still having that problem too, i just forgot which one we were talking about.
mine coughs and doesnt want to go. its been doing that for a month or two and i havent really had time to check out some things to figure out what the prob is.
My Silverstars are a GREAT improvement from the little oem candlesticks. i can actually see at night now.
My Jeep Pics:
post #11 of 13 Old 05-17-2004, 08:02 AM
blk97tj
blk97tj's Avatar
2014 JK Wrangler
hey guys, does anyone know if a clogged cat could cause a vehicle to not start? My jeep just spins but it won't start and it's driving me crazy. Thanks for the help
-Dusty
2014 Wrangler Unlimited
4" lift on 35's
blk97tj is offline
post #12 of 13 Old 05-18-2004, 07:33 PM
topless97je
it both rotates and clicks, right? i would imagine it could be the cat. might wanna look
or what about the battery or yer timing
are there any other symptoms
My Jeep Pics:
post #13 of 13 Old 05-18-2004, 07:49 PM
blk97tj
blk97tj's Avatar
2014 JK Wrangler
mine would just spin and not start but it turns out that mine was the crankshaft position sensor. It got against the header and melted.
4" lift on 35's
blk97tj is offline
Help, getting sea sick Existence JK Wrangler Technical Forum 8 12-01-2009 10:21 PM
sick jeep rickr TJ Wrangler Technical Forum 5 12-20-2007 10:54 AM
sick of my slushbox.... LilViper95 TJ Wrangler Technical Forum 19 12-15-2005 06:23 PM
Sick TJ THEKEEB17 TJ Wrangler Technical Forum 13 04-05-2005 09:22 PM
My jeep is sick 97TJGUZZY TJ Wrangler Technical Forum 10 04-29-2003 08:33 PM
