Should My Differential Fluid Be Milky Gray In Color? - JeepForum.com
post #1 of 6 Old 06-25-2004, 11:06 AM Thread Starter
samsammy23
I was submerged a couple of time yesterday past my diffs. When I drained the rear fluid, the color is a milky gray. I assume this is not the color it should be. Did it change with the mixture of water?
Chad.
samsammy23 is offline
post #2 of 6 Old 06-25-2004, 11:20 AM
RockPaws
RockPaws's Avatar
It sure did. The milky color is due to water in the oil. Be glad you changed it when you did. Prolonged use in this condition would have cost a lot more than a fluid change.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 6 Old 06-25-2004, 11:36 AM
Down&Dirty
Down&Dirty's Avatar
Yeah, quick and easy to try and prevent. Just extend your breather lines for your diffs and you probably won't have this problem again. Problem is there is no easy way to check for water in there.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's.
'80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane.
Down&Dirty is offline
post #4 of 6 Old 06-25-2004, 11:40 AM Thread Starter
samsammy23
Any suggestions on what to do now? I will probably clean it out with brake parts cleaner, wipe it clean, and then refill with gear oil.
Thanks.
Chad.
post #5 of 6 Old 06-25-2004, 11:57 AM
jd4x4
jd4x4's Avatar
Ya you can extend your breather line from your diff up to the gas tank lid, thats were the origanl one was on your TJ. That will keep water out of your diff.
later
jmd
97 TJ RE 3.5 SF 4.56 gears 33in Procomp's 15x8 blk rockcrawlers SYE & Tom Woods drive shaft
Red Jeep Club Member #108
jd4x4 is offline
post #6 of 6 Old 06-25-2004, 12:43 PM
lawdawg
lawdawg's Avatar
ClearGearz
lawdawg is offline
Milky Pink T-Case Fluid... retroflow TJ Wrangler Technical Forum 16 08-13-2009 08:57 PM
Milky tranny fluid? TJftw TJ Wrangler Technical Forum 5 07-26-2009 11:17 AM
milky fluid in air filter 93chris YJ Wrangler Technical Forum 6 02-25-2008 03:33 PM
Tranny Fluid Color, Milky Gray Spiderman TJ Wrangler Technical Forum 7 09-03-2004 05:31 PM
Milky tranny fluid? kingjrk YJ Wrangler Technical Forum 8 05-14-2003 11:16 AM
