Should I swap my transfer case? - JeepForum.com
post #1 of 6 Old 07-23-2010, 04:13 PM Thread Starter
TJRoberto
I got my eye on a 2005 NV241 Rubicon trasfer case that I want to swap in for my old 1997 NV231.
I want to know what will be the endresult of this swap, having 35" tires, AX-15 tranny and 4.88 gears ?
I know the ratio is 4:1 vs 2.72:1.. but can some one explain this better for me please
any inputs on how easy is the install will be?
thanks
TJRoberto is offline
post #2 of 6 Old 07-23-2010, 04:35 PM
JCWJEEP
2010 JK Wrangler
You will have a lower 4lo, meaning your engine will turn the tires more while using less power.
That transfer case also has a fixed yoke output, as opposed to your stock slip yoke, allowing you to use a double cardan rear drive shaft. So you will need a new rear driveshaft as well as adjustable upper control arms for the rear. I believe the front shaft remains the same.
JC Whitney Jeep Team
JCWJEEP is offline
post #3 of 6 Old 07-23-2010, 06:19 PM Thread Starter
TJRoberto
Thanks for the fast reply JCWJEEP...
So besically if I do swap in the NV241 transfer cases, this will be a good set up since I have a mamual tranny and it will help me avoit stalling the Jeep up hills since I will be using less power from the motor right?
Can I modidy my stock rear drive shaft to be used with the NV241 trafers?
any more inputs are walcome. please let me know if I am missing any info in the future swap...
post #4 of 6 Old 07-23-2010, 06:23 PM
jumbojeepman
1976 CJ7
In low range, yes. In high range, no.
jumbojeepman is offline
post #5 of 6 Old 07-23-2010, 06:54 PM
JCWJEEP
2010 JK Wrangler
The only change is present in 4lo. On road driving, I think, is exactly much the same.
No, you will need to buy a new driveshaft.
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
JCWJEEP is offline
post #6 of 6 Old 07-24-2010, 11:02 AM Thread Starter
TJRoberto
Just to make sure the swap will be a straight bold it right? Besides the Rear drive shaft work!!!
For your experts out there, do you guys recommend this mod?
np241 , swap , tj , transfer case
YJ to TJ transfer case swap motobob TJ Wrangler Technical Forum 13 03-13-2011 09:45 PM
Transfer Case Swap TedderX_ TJ Wrangler Technical Forum 1 05-16-2010 04:13 PM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
Swap transfer case xinys JK Wrangler Technical Forum 4 06-23-2009 07:00 AM
NP-231 transfer case swap BBCAT TJ Wrangler Technical Forum 4 12-09-2008 10:41 AM
