Should i regear to 4.88 or 5.13 for 33" tires - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Should i regear to 4.88 or 5.13 for 33" tires
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineThe ULTIMATE "Selectable" Locker System! BroughFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-16-2014, 11:56 AM   #1
Nicyutrick
Which one is prefered? This car is going to be on the freeway more than the dirt.
Nicyutrick is offline   Reply With Quote
Unread 04-16-2014, 12:03 PM   #2
biffgnar
biffgnar's Avatar
Your axles (D30 & D35) max out at 4.88
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote
Unread 04-16-2014, 12:05 PM   #3
freeskier93
freeskier93's Avatar
I'm personally a fan of 4.88 with 33s and the 5spd manual. With your 6spd manual overdrive (6th) isn't quite as tall so you'd be running a bit higher RPMs at highway speeds. Either 4.56 or 4.88 would be good choices in my opinion, 5.13 would be to much and might not be possible depending on the axles you have.
Build Thread
My life in 2010: Chronicles of painting my Jeep
Axle Re Gear and Swap
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote
Unread 04-16-2014, 12:26 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
What engine and transmission do you have? And is it a Rubicon?
HINT: Fill out your Profile as requested in the Stickies at the top of the threads so we don't have to ask these types of questions.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Unread 04-16-2014, 12:28 PM   #5
biffgnar
biffgnar's Avatar
While his profile could use some work, doesn't it identify the engine and transmission? And those answers tell us whether it is a Rubicon.
Unread 04-16-2014, 01:20 PM   #6
Jerry Bransford
His profile was empty when I checked it earlier today.
Getting Savvy...
Unread 04-16-2014, 07:35 PM   #7
jaspepp
I run the 2.5 with 33's and 4.88 and think it is acceptable.
"Idaho sucks!!!! Tell California"
jaspepp is offline   Reply With Quote
Unread 04-16-2014, 07:46 PM   #8
robncar
We're BACK!!!
robncar's Avatar
While this post is strikingly similar to your poll on the same topic...
http://www.jeepforum.com/forum/f9/do...tires-2330785/
4.88 with 33's, 4-cylinder, and manual transmission.
Your axles are limited to 4.88, 5.13 is NOT an option.
I'll also throw this in...
A bog is worse for an engine than slightly elevated RPM's. Just change the oil and filter at 3K intervals.
B O U G H T - I T - B A C K ! ! !
11/03/2013
______
|_____|
(O|||||||O)
|______|
[]====o=[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Unread 04-16-2014, 11:08 PM   #9
Nicyutrick
So now the question is everyone, 4.56 or 4.88?! Alot of people are saying 4.88 why? Why not 4.56?
Unread Yesterday, 06:41 AM   #10
JBTJ
Unless he swaps out axle's. But, we know he won't.
JBTJ is offline   Reply With Quote
Unread Yesterday, 06:54 AM   #11
joe_jeep
2715 rpm at 65
2920 rpm at 70
its the only good option for a 4cyl, and the 4cyl wont mind the rpms.
glfwda #6624
joe_jeep is offline   Reply With Quote
Unread Yesterday, 07:04 AM   #12
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
4.88 so you have more low end.
You do turn slightly higher RPM on the highway (as Joe noted above with the exact #s), but those 200 extra RPM on the highway are worth the trade off for the better low end power.
Wheelin98TJ is offline   Reply With Quote
Unread Yesterday, 08:44 AM   #13
robncar
We're BACK!!!
robncar's Avatar
Yep, didn't think he'd swap axles in a 4-cylinder TJ. Also, he's still bringing up 4.56. You can't save them all...
11/03/2013
______
|_____|
(O|||||||O)
|______|
[]====o=[]
Unread Yesterday, 10:17 AM   #14
Nicyutrick
Alright cool! Thanks everyone for all the help! 4.88 it is!
