Should I Cut My Jeep in Half and Build a Brute? - Page 5 - JeepForum.com
View Poll Results: Should I Cut my TJ in Half and Build a Brute?
Yes 71 67.62%
No 34 32.38%
Voters: 105. You may not vote on this poll
post #61 of 83 Old 06-30-2014, 04:00 AM
TJSIDNEY
Or You could do the JK8 for less than 130k.. and have something really new.. http://www.quadratec.com/products/12503_8000_07.htm
Have you ever had someone say “I read online that….” Really? You read it online so that makes it true? Sometimes yes, but where did you get your information?
TJSIDNEY is offline
post #62 of 83 Old 06-30-2014, 09:48 AM Thread Starter
FlowmasterMufflers
Thanks for the suggestions guys. Don't get me wrong, the new Brutes and JK8's are cool but if I could afford one of those I wouldn't be driving a 1981 Ford Escort to work everyday to support my Jeep addiction.
FlowmasterMufflers is offline
post #63 of 83 Old 06-30-2014, 09:54 AM
dustinridgway
Should you build a brute
I am in the process of doing the same. I started with a 06 Rubicon. I choose to do this because I put a 5.3 in it and knew I would be throwing out everything (interior included) but the axles and transfer case. If you plan on keeping everything else as is, go for it with the jeep you have. If your going to change a bunch of stuff start over. The line-x will be a non-issue. Just wire wheel it off to the floor seam and when you have finished welding it back and seam sealing go back to line-x and have the cover the new areas. One last thing, it is significantly easier with a good donor vehicle. If you start with a basket case that has been wrecked it will be more difficult and expensive.
Good luck
dustinridgway is offline
post #64 of 83 Old 06-30-2014, 10:02 AM Thread Starter
FlowmasterMufflers
Good luck
Thanks a lot! Best of luck to you as well!
post #65 of 83 Old 06-30-2014, 10:41 AM
TJSIDNEY
I bet that 1981 Escort sounds good, considering you work at Flowmaster.
TJSIDNEY is offline
post #66 of 83 Old 06-30-2014, 12:06 PM Thread Starter
FlowmasterMufflers
She's definitely a head turner!
post #67 of 83 Old 06-30-2014, 03:51 PM
danielbuck
1946 CJ2
just a thought on the line-x, I wonder how dry ice would work? Make it real brittle so it chips off easy.
danielbuck is offline
post #68 of 83 Old 07-03-2014, 03:19 PM Thread Starter
FlowmasterMufflers
That's definitely a creative approach. I'll have to drop by Line-X and see what they have to say.
post #69 of 83 Old 07-03-2014, 05:25 PM
Moabrubi
The only way to remove it is a sharp knife, prybar and brute strength.
Trust me.. name a method we've tried it.
Moabrubi is offline
post #70 of 83 Old 07-03-2014, 05:26 PM
Moabrubi
The easiest way is if it holds together and peels off at once. Its a pain in the *** when it chips and peels apart.
Moabrubi is offline
post #71 of 83 Old 07-03-2014, 05:32 PM
danielbuck
1946 CJ2
I've never seen line-x peel, but maybe with some prying it might?
post #72 of 83 Old 07-03-2014, 05:37 PM
Moabrubi
Yea it can be really tough depending on how well it bonded but I've done it many times.
I usually pry enough just to get an edge then grab it with pliers or just my hands and yank on it.
Moabrubi is offline
post #73 of 83 Old 07-07-2014, 05:42 PM Thread Starter
FlowmasterMufflers
Yeah, that makes sense. I definitely wasn't planning on taking all of the Line-X out. I would really only need to remove enough so that I could get to the areas that need to be separated.
post #74 of 83 Old 07-07-2014, 08:22 PM
MrHinzman
Gotta say that's a nice rig, I wouldn't do it. Buy a junker...if not to practice on first anyway.
MrHinzman is offline
post #75 of 83 Old 07-07-2014, 10:02 PM Thread Starter
FlowmasterMufflers
Thanks! I took a long drive through the Redwoods to the coast just north of Jenner, CA with my girlfriend yesterday. It was about 80 degrees outside so we had the top and doors off all day. I really started to second guess my plans. The drive reminded me of why I originally bought a soft top Jeep and not a pickup.
brute , exhaust , flowmaster , technology
