Should I change OPDA? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Should I change OPDA?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueRough Country Lift Kits and Parts!
Unread 06-23-2014, 06:07 PM   #1
Groove508
Have an '05 Rubi with 84k, I thought I better check the OPDA and it has been pulled or replaced because there are timing marks in yellow paint pencil on it. The gear shows wear but spins easily with no slop, etc. The cam gears sure shows some wear also but I don't really know what's excessive? I assume once the cam gear has wear, it's just gonna keep wearing out the OPDA gear(s). I went ahead and ordered a Crown unit. Should I go ahead and replace it or wait for more signs of wear, etc. I know there is tons of info about this but wanted a similar member's opinion.
Thanks!
Groove508 is offline   Reply With Quote
Unread 06-23-2014, 06:10 PM   #2
Rockchucker22
I just got a 05 with 40,000 miles and the first thing I did is order the crown unit, I'm not taking any chances.
Rockchucker22 is offline   Reply With Quote
Unread 06-23-2014, 06:22 PM   #3
Groove508
Did you change it yet? How did your cam shaft gear look?
Unread 06-23-2014, 06:43 PM   #4
Rockchucker22
I JUST got the jeep less than a week ago so I'm still waiting to get the crown unit.
Unread 06-23-2014, 11:50 PM   #5
06philaTJ
Replace it with the crown unit irregardless of wear. It is really easy to remove the old and reinstall the new OPDA, did mine in 1/2hr taking my time. If you have wear on your cam gear, then your OPDA is already defective. The OPDA gear is the sacrificial gear so the cam gear should have minimal to no wear on it if it's working properly. My cam gear looks fine but my OEM OPDA gear had excessive wear at only 54k.
06philaTJ is offline   Reply With Quote
Unread 06-24-2014, 01:45 AM   #6
joe_jeep
Swap it. If u need a cam later, u can change the gear on the Opdg at the same time.
mine lasted just over 100k. i got a factory one, with the stripperguy mod.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote
