Should I change fluids - JeepForum.com
 6Likes
post #1 of 22 Old 06-19-2017, 06:34 PM Thread Starter
Dig1966
I Just bought a 2004 Jeep Wrangler Rubicon with 140,000 miles. Former owner did take the Jeep off road. Seems to be well taken care of and I am going to change the oil. I was wondering if there is wisdom in changing the transmission fluid and the transfer case fluids? Thanks for any advice you can give me.
Dig1966 is offline
post #2 of 22 Old 06-19-2017, 06:37 PM
btn
Do you know the last time the owner changed them? If not, I'd change the transmission, transfer case, and both diff fluids, just to be safe and start over with a fresh maintenance schedule.
I'd also change steering fluid and brake fluid, but that's more involved. Maybe antifreeze as well?
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is online now
post #3 of 22 Old 06-19-2017, 06:39 PM
Raist11
Raist11's Avatar
Only you can decide that. Will it ensure all the fluids are good? Yup. Would I do it? Nope. But many people probably would. It comes down to what will make you feel comfortable with it. Check the level, color of all fluids and make your decision from there.
Current: '00 TJ Sport
Past: '98 TJ Sport - lots of aftermarket
Raist11 is online now
post #4 of 22 Old 06-19-2017, 07:04 PM
JEK3
JEK3's Avatar
May not be necessary, but it's never a BAD idea to change fluids, and the most it will hurt is your wallet (unless you do it wrong).
JEK3 is online now
post #5 of 22 Old 06-19-2017, 07:08 PM Thread Starter
Dig1966
Thanks all!! Any downside to going with synthetic oil?
Dig1966 is offline
post #6 of 22 Old 06-19-2017, 07:13 PM
2jhanna
Mo money!
jhanna
denton county, tx
2jhanna is offline
post #7 of 22 Old 06-19-2017, 08:27 PM
wadewen
If the fluids are clean and the appropriate color, I'd leave them.
His: 97 TJ Sport -
FSM Link:
Hers: 02 WJ Overland -
FSM Link (have to create login) -
wadewen is offline
post #8 of 22 Old 06-19-2017, 11:25 PM
Shark_13
If you are doing it yourself and have the time/money, definitely. It's not that much for fluids.
No need for synthetic.
Shark_13 is online now
post #9 of 22 Old 06-20-2017, 04:29 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
I just bought an 03' Rubi myself. Luckily the PO (original owner) kept every service record from day one. All fluids (including axles) recently changed, new clutch and windshield. He did every service, on time and religiously. The best is that he NEVER took it offroad.
TheBoogieman is offline
post #10 of 22 Old 06-20-2017, 05:31 AM
Mattific
That's pretty much how I got my 04 from an older gentleman (original owner) who used it to go skiing pretty much exclusively. I got every service record and all of it was through the dealer. I don't think it had ever been more than 40 miles from where he bought it
TheBoogieman likes this.
Mattific is online now
post #11 of 22 Old 06-20-2017, 08:30 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you want to know, change them all. If you don't want to know, leave them be. It is about that simple and has nothing to do with wisdom, just knowing.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #12 of 22 Old 06-20-2017, 09:17 AM
TJnBC
I ALWAYS refresh the fluids with any vehicle I buy...unless I have the proper service records.
2006 LJR...the madness begins again
TJnBC is offline
post #13 of 22 Old 06-20-2017, 09:21 AM
toximus
I know too many people who never follow the service schedule and don't use the proper fluids (think: manual transmission oil low? ATF will work. Or: 10w30 was good enough for my dad so it ought to work just fine in this European sports car.).
Even if you have service records it might be a good idea to just change all fluids. I'd even include radiator fluid on that list. They may have topped it up with a hose for all you know and it'll crack once winter comes.
toximus is offline
post #14 of 22 Old 06-20-2017, 09:32 AM
TheBoogieman
Originally Posted by toximus View Post
I'd even include radiator fluid on that list. They may have topped it up with a hose.
What is this radiator fluid you speak of? Is it the Orange or Green stuff I feed to thirsty unwanted animals around my house? (JK)
p.s. I've never topped up the radiator fluid with my hose.
post #15 of 22 Old 06-20-2017, 09:41 AM
toximus
I use the purple stuff that I put in my washer fluid. It's just companies trying to scam us with different containers anyway. /s
toximus is offline
