Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? - JeepForum.com
post #1 of 4 Old 07-07-2009, 09:47 AM Thread Starter
Lemmiwinks
Before I started installing my lift in my 03' TJ, I wanted to mark down some measurements.
With the jeep on jack stands (supported at the axles) using a weighted string (plum bob, centered with the wheel), I measured the distance between the string and the rotor. It appears that both front and rear axle sits .5" towards the passenger side.
After I installed the rear track bar re-locator bracket the rear axle was now .75" towards the passenger side.
Is this normal for the axel to be located more to the passenger side by this distance? About to install my adjustable track bar and wanted to make sure I am aligning everything correctly.
Lemmiwinks is offline
post #2 of 4 Old 07-07-2009, 09:48 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
not normal IMHO. my axles are both centered within 1/16" using adjustable track bars.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 4 Old 07-07-2009, 09:54 AM
TNeustadt
Using a track bar re-locator bracket in the rear you are stuck with whatever you end up with, which is varies by the height of the lift installed. The only way to get it even, is to get lucky or use an adjustable track bar.
TNeustadt is offline
post #4 of 4 Old 07-07-2009, 10:27 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
1/2" doesn't hurt anything.
TheBoogieman is offline
Front Axle & Rear Axle is off centered to the passenbe off centered by .5" pass side? Lemmiwinks TJ Wrangler Technical Forum 4 07-09-2009 06:46 AM
Rear axle not centered after RE 3.5" lift csabo98 TJ Wrangler Technical Forum 17 06-08-2009 09:43 PM
Passanger side axle seal is bad AGAIN 94YJEEPER YJ Wrangler Technical Forum 18 03-16-2009 05:45 PM
Front Axle Off-Centered gould62 TJ Wrangler Technical Forum 4 02-06-2009 09:36 AM
FRONT axle shifted to the passanger side Schwalby TJ Wrangler Technical Forum 5 04-11-2008 10:20 AM
