Should the front axle move laterally? - JeepForum.com
post #1 of 16 Old 08-15-2010, 06:15 PM Thread Starter
sethkins88
When I am parked and turn the steering wheel side to side I can see my axle shift from side to side. I know my track bar is loose on the axle side of the bar as I can see the bolt move as I turn the wheel. The bolt is stripped and I cant get it off. I am going to have to take it to a shop. I was wondering if that is what is causing my clunk/pop noise in the front. It gets alot worse in 4x4. It does it from a stand still and while moving slowing and turning
I am thinking because the axle moving it is putting stress on the front drive shaft as I get a clunk/pop and I can feel it bind and pop in the steering wheel and underneath the drivers-side floor board. Would this make sense?
thanks
sethkins88 is offline
post #2 of 16 Old 08-15-2010, 06:18 PM
bairy
Fix the known problem and reevaluate.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #3 of 16 Old 08-15-2010, 06:25 PM Thread Starter
sethkins88
It is in the process of getting fixed. I just wanted to know if anyone had a similar issue that was from the same culprit.
post #4 of 16 Old 08-15-2010, 06:27 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
thanks
No, the axle should not move side to side at all. Zero, nada. Fix the passenger-side loose mounting issue, that connection must be stone-cold solid with zero side-to-side or up-down movement allowed.
Jerry Bransford is offline
post #5 of 16 Old 08-15-2010, 06:30 PM Thread Starter
sethkins88
Thanks Jerry, I was pretty sure it shouldnt be moving at all. After the bolt/bushing gets replaced, Ill post an update.
post #6 of 16 Old 08-15-2010, 06:54 PM
johnny9
mine has come loose a couple times from hard wheeling and it started makering the clunk noise bad yesterday,i tightened it up this morning and its all good again..
and yes,the bottom bolt on the t.bar really is a torx work of art lol.
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #7 of 16 Old 08-15-2010, 08:12 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
But, but, but, I thought a loose trackbar bolt would result in instant and severe Death Wobble.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #8 of 16 Old 08-15-2010, 08:34 PM
Stu Olson
Stu Olson's Avatar
Naw....it will wait until you are about 800 miles away from home on a long distance wheeling trip....then, it will start with the death wobble.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #9 of 16 Old 08-15-2010, 08:45 PM
DevilDogDoc
Bwah ha ha!!!!!
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #10 of 16 Old 08-15-2010, 08:47 PM
-ExDementia-
1991 XJ Cherokee
Originally Posted by DevilDogDoc View Post
Bwah ha ha!!!!!
Yucca Valley!! I grew up there.
"The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to get the job done.'" - George Carlin
Click
for the elusive search button everyone talks about.
-ExDementia- is offline
post #11 of 16 Old 08-15-2010, 08:51 PM
jdhallissey
EX you should go back too. San Diego has given you the eviction notice!
jdhallissey is offline
post #12 of 16 Old 08-15-2010, 09:30 PM
DevilDogDoc
Lucky you! At least you got to get out, I was abandoned here....
post #13 of 16 Old 08-15-2010, 09:43 PM Thread Starter
sethkins88
Thats the thing, I dont have a Death Wobble. Does a loose bolt on the trackbar usually give a death wobble?
post #14 of 16 Old 08-15-2010, 09:46 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It can, but I was poking fun at all the single solution silly boys that offer it up any time a DW question is brought up.
I am Savvy
mrblaine is offline
post #15 of 16 Old 08-15-2010, 09:54 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Whoa there old man, this is TJ Tech!
If you want to poke fun, try the XJ Forum.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
How to move front axle forward? GMC7000 TJ Wrangler Technical Forum 17 03-20-2009 10:47 AM
Why cant I move my axle? kllrbee TJ Wrangler Technical Forum 16 05-26-2008 10:14 PM
Front axle forward - diff & DPA contact - Move the PS box? LOCKED UP YJ Wrangler Technical Forum 12 08-01-2007 11:49 AM
How far will the OME bracket move my axle? cpleasant TJ Wrangler Technical Forum 1 04-19-2007 11:49 PM
Move the D44 up front? lj_wil TJ Wrangler Technical Forum 8 11-02-2006 02:16 PM
