shock length ? - JeepForum.com
post #1 of 4 Old 06-03-2003, 12:04 AM Thread Starter
sevenslats
shock length ?
right now my jeep has a 2" spring lift, and the shocks that came with that lift. i've noticed the shocks limit my downward travel.
I'm buying some 4" springs, and need shocks to match.
my question is what's the compressed/extended length for the shocks that i need?
TJ on 33s
sevenslats is offline
post #2 of 4 Old 06-03-2003, 03:52 AM
blkTJ
blkTJ's Avatar
as long as you have 2" of bumpstop extension go with the OME long travels. they are something like 26.5" extended front and 24" extended rear. I don't remember the compressed length but your fine with the extra 2"s of bumpstop. FYI, your shocks will ALWAYS limit your downward travel unless you have limiting straps.
97 TJ, some mods...
all those involved in the creation of that ill-advised club have been sacked...
blkTJ is offline
post #3 of 4 Old 06-03-2003, 09:53 PM Thread Starter
sevenslats
btt
TJ on 33s
post #4 of 4 Old 06-04-2003, 03:46 AM
blkTJ
blkTJ's Avatar
hmmm, not good enough for ya huh?
try this...
to find your compressed length, (assuming your not increasing the bumpstops from what you have now), take the ride height of your shocks and subtract the distance between the rubber bumpstop and the axle spring pad that it will contact.
for extended length, the more the better. the specs I mentioned above give respectable droop.
97 TJ, some mods...
blkTJ is offline
shock length? kkchevy3 YJ Wrangler Technical Forum 2 09-15-2009 03:25 PM
shock length???? bradp37 YJ Wrangler Technical Forum 0 01-16-2009 04:10 PM
shock length codymparmy TJ Wrangler Technical Forum 1 10-18-2007 08:11 AM
Shock Length PARTSPHIL YJ Wrangler Technical Forum 5 12-05-2006 12:33 PM
Shock Length Help TexanTJ TJ Wrangler Technical Forum 5 09-26-2006 03:02 PM
