Shock length for a 4" Full Traction long arm - JeepForum.com
post #1 of 5 Old 05-15-2008, 08:55 PM Thread Starter
Hopper_
Can someone tell me what length shocks I'll need for this suspension setup?
I'm looking into getting some Bilstein 7100s, but I don't know what length to look for.
Would a shock that's 25.8" extended and 15.8" collapsed work for either the front or the rear? It works out to roughly 10" of travel
Thanks
2004 Rubi - Stockish, nearly insignificant mods and 265 KM2s
1979 Ford Bronco - 400/T-18/NP205, 5.5" lift, 37x12.50s, custom long arm
1978 CJ-5 - Mostly stock, 304/T-150/D20, 3" lift 34x9.50s, 8k winch, hard top/doors, dual exhaust
Hopper_ is offline
post #2 of 5 Old 05-15-2008, 09:25 PM
will04wrangler
will04wrangler's Avatar
Really? Go measure your shock height. Add 4 inches to that. Find a shock where that number is right in the middle and you're set.
will04wrangler is offline
post #3 of 5 Old 05-15-2008, 09:34 PM Thread Starter
Hopper_
I assume that the long arm is going to have a lot more droop than the short arm is going to be able to muster. Won't that mean that I'm going to need a little more shock than just +4"?
Hopper_ is offline
post #4 of 5 Old 05-16-2008, 11:31 AM
will04wrangler
A long arm isn't going to be much difference. Yes, it will flex better, but think about this: A 4" short arm lift will stuff the tire under the flare (with a 4" longer shock.) Will you want that long arm flexing farther than that? (Otherwise, into your fender flare.) It's gonna have about the same amount of travel because you're gonna have to bumpstop it before the tires hit the flares. The 4" of lift is what limits you, not the arm length.
So get your shock height at ride height. Find a shock where that number sits in the middle of the extended and compressed numbers and you're set. Shocks built for Jeeps should give you no problems.
Hope this helps,
-Will
post #5 of 5 Old 05-16-2008, 03:46 PM Thread Starter
Hopper_
Thanks bud; guess I was overthinking things again
Hopper_ is offline
Upgrade from 3" Full Traction Economy Lift to Long Arm Jeff65SS TJ Wrangler Technical Forum 2 12-06-2009 05:57 PM
Installed Full Traction 4" long arm, pics Slc JK Wrangler Technical Forum 2 03-20-2008 08:40 AM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 01:46 AM
Rubicon Express 4.5 L.A. vs. Full Traction 4" long arm?? David Hinton TJ Wrangler Technical Forum 21 08-23-2005 12:32 AM
Full Traction 6" Long Arm on an 03 Rubicon Seapahn TJ Wrangler Technical Forum 22 06-21-2004 02:08 AM
