Shock Extension - JeepForum.com
post #1 of 3 Old 02-23-2009, 03:46 AM Thread Starter
waldoo
Shock Extension/Relocator
Hi There,
Is it required to install Shock Extension/Relocator on a 2006 tj with a 2" suspension lift kit???
What is the benefits & drawback of this mod???
Thanks...
waldoo is offline
post #2 of 3 Old 02-23-2009, 07:15 AM
Libtekguy
No, you don't need it. It's only needed if you're running an SYE kit. SYE kits require you to angle up your pinion/axle; which often causes your shocks to come in contact with your axles. The Extension bracket moves the shock away from the axle enough to prevent this contact.
Current: 2014 WK2: 2" Eibach. 20" Overland wheels. 275/55R20 BFG KO2.
Libtekguy is offline
post #3 of 3 Old 02-23-2009, 07:31 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
NO.......
TheBoogieman is offline
Do I need a shifter extension if.... Beepin' TJ Wrangler Technical Forum 8 03-06-2010 06:44 PM
Rough Country Budget Boost no front shock extension ??Why?? Mike_Motorbike TJ Wrangler Technical Forum 9 12-09-2009 02:56 PM
Question On Shock Mount Extension Brackets... JPROBSON3 TJ Wrangler Technical Forum 9 03-19-2009 07:28 AM
Rear shock extension; FYI richs347 TJ Wrangler Technical Forum 0 01-25-2008 07:51 PM
Rear Shock Extension - Mini How-to instg8tor YJ Wrangler Technical Forum 3 05-18-2007 06:58 PM
