Shock coil spring came out of it seat. HELP - Page 2 - JeepForum.com
post #16 of 22 Old 07-26-2010, 10:28 AM
ElementX
Originally Posted by Knuckelhead View Post
What year TJ's had rear spring retaining clips?...
When I had a '97 it had retaining clips on all 4 corners. Maybe the previous owner added them?
I just went outside to look at my '98 and it has retaining clips on the front only (both sides).
'98 TJ Sport
ElementX is offline
post #17 of 22 Old 07-26-2010, 05:39 PM Thread Starter
SolidBrass
Tuff Country (yes the brand spelled that way) is no help at all...
I've got to buy a new one. From a retail outlet, then send my broken one back. They will "test" it and then decide if they will credit the place I bought the replacement from (original vendor)???
This is no way to "warranty" your product. I give them a THUMBS DOWN!
SolidBrass is offline
post #18 of 22 Old 08-04-2010, 03:41 PM
tri486
Originally Posted by IslandTJ View Post
My Jeep only had 1 spring retainer bracket located on the front driver's side coil .
Mine is the same way...i wonder if it was suppose to be like that
Running over pot holes is the closest thing to 4x4 in the city....
tri486 is offline
post #19 of 22 Old 08-04-2010, 06:53 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes it is. But, it's easy to put one on the other side...
Knuckelhead is offline
post #20 of 22 Old 08-06-2010, 02:56 PM Thread Starter
SolidBrass
Pinion Adj. and U-Joint replacement?? How do U remove shaft with SYE
wrong post
post #21 of 22 Old 08-07-2010, 12:42 PM Thread Starter
SolidBrass
Well i tried to flip the shocks, but the bushing sleeve on bottom end thwarted me in my efforts. Just did the work for nothing.
post #22 of 22 Old 08-07-2010, 12:51 PM
ElementX
I've noticed that not all springs will allow you to use a clip on the passenger side. The 4" tera springs I just pulled out the other day were cut appropriately, where as the 4" RC spring I put in is probably 1/4" above the top of the clip. Both brands were fully seated in the spring perches, and the top of the springs were in the notch on the perch
'98 TJ Sport
ElementX is offline
spring , coil
LCAs hitting spring seat/ shock mount plate - anyone else? NotURMailman TJ Wrangler Technical Forum 7 08-21-2009 06:52 AM
Coil Spring cookeab TJ Wrangler Technical Forum 1 04-18-2007 11:14 AM
Coil Spring Conversion DaSham58 YJ Wrangler Technical Forum 8 09-21-2006 04:33 PM
rear shock problem (shock hits coil cup) gundy33 TJ Wrangler Technical Forum 17 04-12-2006 01:59 PM
TJ Coil Spring Spacers? johnmcompton TJ Wrangler Technical Forum 25 09-26-2003 04:04 PM
