Shock coil spring came out of it seat. HELP - JeepForum.com
post #1 of 22 Old 07-25-2010, 10:30 AM Thread Starter
SolidBrass
I'm not sure what keep the rear springs in place but my right rear has been making noise.
So when I investigates It appears the spring is not fully mounted in it 'seat'.
I know I need to raise up the jeep, any tips for getting the spring back in place?
SolidBrass is offline
post #2 of 22 Old 07-25-2010, 10:33 AM Thread Starter
SolidBrass
Here is a photo of the other side that looks to be mounted correctly.
post #3 of 22 Old 07-25-2010, 10:38 AM
Benderff
Benderff's Avatar
I would tap it over with a mallet.
Benderff is offline
post #4 of 22 Old 07-25-2010, 10:44 AM
Bigworm
Yeah, a swift blow with a hammer of sorts should take care of it. If you cant get at the right angle to hit it then a pry bar will do the trick. I used a piece of 2X4 to get one back in and it worked great.
Bigworm is offline
post #5 of 22 Old 07-25-2010, 11:40 AM Thread Starter
SolidBrass
Oddly When I lift it up it is seated where it should be. Set it down and it angles as above. Strange. I did find a loose upper control arm bolt that could have been the noise. I about to go find out.
post #6 of 22 Old 07-25-2010, 12:06 PM
Mousejockey
That spring appears to be sprung. Is the rig leaning to one side?
Mousejockey is offline
post #7 of 22 Old 07-25-2010, 12:30 PM
ElementX
looks like the spring is bent/curved. You'll need to replace it or spin it to line up with the rear suspension's arc/range of motion.
Put the rear up on jackstands so that the rear end can hang, remove the rear wheels, put on some work gloves. Even with a 4" lift, I think you should be able to just grab the spring, and twist it 90 degrees or so to get it into a better position. If not, then jacking up the other end of the axle will drop the problem side enough to do the above.
'98 TJ Sport
ElementX is offline
post #8 of 22 Old 07-25-2010, 12:34 PM
tri486
not to sound stupid or anything but from the pictures...could they be upside down? sorry not to make you sound stupid also cause i know on mine i can accidently turn them upside down and have the same issue..
Running over pot holes is the closest thing to 4x4 in the city....
tri486 is offline
post #9 of 22 Old 07-25-2010, 03:34 PM Thread Starter
SolidBrass
doesn't seem to lean. I've never removed them so they were installed this way. Does "sprung" mean broke/bent?
It didn't stop me from doing a bit of crawling today. Testing clearance with my new Disconnect.
Here's some pick. (Larz is chilling in the shade in one of these)
post #10 of 22 Old 07-25-2010, 03:47 PM Thread Starter
SolidBrass
Do I need a coil compressor to install a new spring? Or with the shock off will I be able to lift it enough to slide in place?
It is not a big surprise as when I recently had a 4 people in it and I felt the back right bottom out on a bump. I've never heard that before then.
post #11 of 22 Old 07-25-2010, 04:52 PM
johnxjeep
I was told the rear springs do not have a right side up. I installed my springs and I hope I did not put them on upside down.
How can you tell ?
Awsome pics BTW.
johnxjeep is offline
post #12 of 22 Old 07-25-2010, 05:20 PM Thread Starter
SolidBrass
I'll call Tuff Country Monday and try and 'enforce' there warranty for a new coil.
One Question? Do Jeeps have coil spring clips? or will simply slide into place. (doesn't sound hard, but lot of difficult things don't)
Originally Posted by johnxjeep View Post
Awsome pics BTW.
Thanks Johnx
post #13 of 22 Old 07-25-2010, 06:25 PM
ElementX
TJ's older than yours have spring retainer clips, but you don't have to worry about that because you probably wouldn't of noticed your problem if you had them.
When you lift your jeep up on jackstands, it should be pretty simple and easy to spin the spring around by hand. The fronts need spring compressors, but the rears don't.
'98 TJ Sport
ElementX is offline
post #14 of 22 Old 07-26-2010, 05:09 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What year TJ's had rear spring retaining clips?...
Knuckelhead is offline
post #15 of 22 Old 07-26-2010, 09:42 AM
IslandTJ
My Jeep only had 1 spring retainer bracket located on the front driver's side coil .
Now Jeeping in Oregon
IslandTJ is offline
spring , coil
LCAs hitting spring seat/ shock mount plate - anyone else? NotURMailman TJ Wrangler Technical Forum 7 08-21-2009 06:52 AM
Coil Spring cookeab TJ Wrangler Technical Forum 1 04-18-2007 11:14 AM
Coil Spring Conversion DaSham58 YJ Wrangler Technical Forum 8 09-21-2006 04:33 PM
rear shock problem (shock hits coil cup) gundy33 TJ Wrangler Technical Forum 17 04-12-2006 01:59 PM
TJ Coil Spring Spacers? johnmcompton TJ Wrangler Technical Forum 25 09-26-2003 04:04 PM
