shock advice needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > shock advice needed
Rough Country LED BracketsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAll Bilstein shocks & struts - Lowest Prices Ever and
Unread Yesterday, 10:08 PM   #1
banjo_picker
shock advice needed
Have: 99 TJ, 31" tires, 2"BB spacers with bumpstop extensions.
Need: New shocks.
If I get Bilstein 5100s, they are adjustable from 0-2" of lift. How should I set them up? At 0" or at 2"? Can I get rid of the bumpstop extensions or should I leave them in?
banjo_picker is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 10:17 PM   #2
Gabe
You can't adjust your ride height via shocks. That is determined by the spring or combination of spring and coil spacers.
Only thing that can be adjusted on your shocks is the dampening, which the 5100s don't do. You just have to make sure you buy them for a jeep with 2" of lift.
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 10:24 PM   #3
banjo_picker
I thought they had a snap ring that lets you set it for different heights. Maybe I am mistaken.
Anyway.. will this shock work with my setup? Should I keep the bumpstop extenders?
Unread Today, 07:17 AM   #4
JBTJ
Plain shocks like that are not adjustable. You need shocks that range from 0-2". Best to measure to be exact though, but they should work well with needed bumpstop extenders.
JBTJ is online now   Reply With Quote Quick reply to this message
