Shock Advice - Page 2 - JeepForum.com
post #16 of 19 Old 06-26-2010, 10:43 AM
SILASPRIT
Originally Posted by LMG23 View Post
Well I am running 31's with a 1' BL. I will need a bumpstops I assume ?
I'm not sure... You might have to go flex and see how you do. I am assuming you will need them.
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
post #17 of 19 Old 06-26-2010, 11:42 AM
TheDragonfly
Originally Posted by SILASPRIT View Post
They extend the bump stop so it will hit before your tire eats your fenders when flexing.
But more importantly they prevent the shock from bottoming out too often and blowing out the shaft seals or breaking the bar pins.
TheDragonfly is offline
post #18 of 19 Old 06-28-2010, 09:13 AM
Fargo
X2 - As someone else said the shocks are longer than stock and they will bottom out if you don't extend the bumpstop. This could destroy your brand new shocks. I recommend extending the bumpstop. I think the spring spacer mentioned to regain the suspension travel you loose to the bumpstop extension.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #19 of 19 Old 07-02-2010, 06:18 PM Thread Starter
iceman1947
Shock Advise
I just installed OME Sport shocks and the OME steering stabilizer. WOW! What a difference ..... It's like a whole new vehicle. It's even quieter now that I don't have all the rattles. I'm sold big time.
iceman1947 is offline
shock , advice , bilstein , 5100 , tj , wrangler
Advice on new Tires? (Shock advice) NorthStar TJ Wrangler Technical Forum 8 07-13-2009 06:46 AM
shock advice deryk111 TJ Wrangler Technical Forum 0 06-15-2009 06:18 PM
shock advice OOwrangler TJ Wrangler Technical Forum 20 02-26-2009 08:33 AM
Looking for shock advice jeep'd TJ Wrangler Technical Forum 14 02-15-2008 08:38 AM
Shock advice Huebie TJ Wrangler Technical Forum 2 07-09-2004 07:48 PM
