Shock Advice - JeepForum.com
post #1 of 19 Old 06-24-2010, 07:23 PM Thread Starter
iceman1947
Shock Advice
I have a 1999 wrangler with a 2 inch lift. I need to replace my shocks. I do mostly DD and occassional light off roading. I wanted to install Bilstein 5100 series but they don't make them for a TJ with a 2 inch lift. Any suggestions on what I could use? Thanks ....
iceman1947 is offline
post #2 of 19 Old 06-24-2010, 07:43 PM
TJRubicon06
OME, you cant go wrong with them. I have a run RE BB pucks with OME shocks for a while now and the ride is great.
06 TJ Rubicon
Black Jeep Club member #95
1-20-13
Getting
TJRubicon06 is offline
post #3 of 19 Old 06-25-2010, 06:07 PM
masedd
OME just make sure you don't order the long travel,as they are too long for 2 inch. Quadratec.com has a shock adviser
masedd is offline
post #4 of 19 Old 06-25-2010, 09:11 PM
mudb8
want it rite or rite now?
mudb8's Avatar
OME N66c front and OME N67 for the rear.
the front will operate on stock bumpstop extensions, the rear needs 1.25" extensions.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #5 of 19 Old 06-25-2010, 09:21 PM
LMG23
What OME will work for a stock height tj ?
LMG23 is offline
post #6 of 19 Old 06-25-2010, 09:25 PM
LMG23
or the Bilstein HD ? what is the part number that will work on a stock height tj ? I have been looking but have come up with nothing
LMG23 is offline
post #7 of 19 Old 06-25-2010, 09:37 PM
Fargo
Bilstein has one for the Rubicon that is about an inch longer than stock. It gets you close and if your not disconnecting it will be long enough for you.
Personally I just purchased the Rancho RS9000XL adjustable shocks for the 2" lift I am installing this weekend. Right now they have a mail in rebate for $100. I've seen the shocks online for about $80 and I picked mine up locally for $85. When you subtract the rebate thats only $60 per shock. Some very knowledgable people on this forum recommend this shock so I felt comfortable with it. I'll let you know in a couple of days how I like it personally.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #8 of 19 Old 06-25-2010, 09:50 PM
mudb8
mudb8's Avatar
N66c/N66 fronts.
the rear N67 shocks require a minimum of 1" bumpstop extension, and are great with the addition 3/4" BB spacers front and rear........ or a 3/4" rear and 1.75" front for leveling purposes.
mudb8 is offline
post #9 of 19 Old 06-25-2010, 09:54 PM
inglisleslie
X2. I just got the OME N67(rear) and N66(front). They are smoother than whipped butter
inglisleslie is offline
post #10 of 19 Old 06-25-2010, 10:02 PM
LMG23
Excuse the dumb question, but why would I need spacers if I am not lifting the jeep ? I am leaving in the stock springs. Also, how much more work would this entail ? I was hoping for a "take off, put on" type of job.
LMG23 is offline
post #11 of 19 Old 06-25-2010, 10:22 PM
LMG23
And where would I be able to buy the rear 1.25 bump stops ?
LMG23 is offline
post #12 of 19 Old 06-26-2010, 05:58 AM Thread Starter
iceman1947
What do the bumpstop extensions do?
post #13 of 19 Old 06-26-2010, 10:24 AM
LMG23
bump
LMG23 is offline
post #14 of 19 Old 06-26-2010, 10:32 AM
SILASPRIT
Bump stops have just as much to do with tire size as they do lift. If you are NOT lifting your jeep, then no you will not need bump stops if you are still running the stock tire size.
They extend the bump stop so it will hit before your tire eats your fenders when flexing.
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
post #15 of 19 Old 06-26-2010, 10:35 AM
LMG23
Well I am running 31's with a 1' BL. I will need a bumpstops I assume ?
LMG23 is offline
shock , advice , bilstein , 5100 , tj , wrangler
Advice on new Tires? (Shock advice) NorthStar TJ Wrangler Technical Forum 8 07-13-2009 06:46 AM
shock advice deryk111 TJ Wrangler Technical Forum 0 06-15-2009 06:18 PM
shock advice OOwrangler TJ Wrangler Technical Forum 20 02-26-2009 08:33 AM
Looking for shock advice jeep'd TJ Wrangler Technical Forum 14 02-15-2008 08:38 AM
Shock advice Huebie TJ Wrangler Technical Forum 2 07-09-2004 07:48 PM
