Quantcast Shifts hard into 2nd - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Shifts hard into 2nd
Old 10-09-2008, 01:16 AM   #1
Curt99
My tj has always been a bit stiff shifting from 1st to 2nd. Has anyone experienced this.
Curt
Curt99 is offline   Reply With Quote
Old 10-09-2008, 06:18 AM   #2
exminnesotaboy
common with the AX-15 transmission for some folks. Mine has shifted like that for the last 30k miles and not gotten worse. I just picked up some RedLine MTL tranny fluid and will see if that helps. Some others have done the same thing: some with good results, some with no change.
http://www.juanvergostudios.com/tony
97 TJ 4.0L d30/35 5sp 2"bb 32"M/T MTX's
exminnesotaboy is offline   Reply With Quote
Old 10-09-2008, 08:00 AM   #3
01TJHigh_rdr
I have the same issue on my NV3550. I changed the oil and it helped a little but not much. I just learned to live with the fact that Jeep's are not a precision piece of machinery. If you don't know how learn to double clutch, it will make life a lot easier.
01TJHigh_rdr is offline   Reply With Quote
Old 10-09-2008, 08:41 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
My 98' has been doing that for years.Worn synchronizer in transmission.I switched to Redline MT-90 and it hasn't gotten any worse.It's worse in the winter.
TheBoogieman is offline   Reply With Quote
Old 10-09-2008, 09:55 AM   #5
grinwa
Mine, too. Been like that for 3 years
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline   Reply With Quote
Old 10-09-2008, 10:16 AM   #6
rbarnes
Mine has been like that for years. The Redline MLT did not really help. It hasn't gotten any worse over time. You just know it is going to happen.
rbarnes is offline   Reply With Quote
Old 10-09-2008, 04:23 PM   #7
Curt99
I bought it new and on a return to the dealer for service they did say it would need a short break in period, I just didn't think it would take this long. I haven't double clutched since I owned a Simca in 1960's.
Curt
Old 10-10-2008, 04:12 PM   #8
mud n rox
Buzzin' Half Dozen !!!
mud n rox's Avatar
My 2001 32rh has done it since I have owned it (bought used). Even when manually shifting it goes from 1st to 2nd hard. It has always done it and never gotten any worse. I had the trans serviced flushed and filled and new filter. Didnt make a bit of difference. I just figure that its the way jeep trans are suppose to be.
2001 TJ - With a little lift, some armor, four mud tires, and a few decals.
Caution: Rock and a hard place just ahead.
mud n rox is offline   Reply With Quote
Glock Forum
