shifting into 2nd gear is grindy - JeepForum.com
post #1 of 11 Old 11-08-2011, 05:17 PM Thread Starter
schmud6
I own a 2000 2.5L 4 cyl manual wrangler. recently i have been having problems shifting into second gear. It kind of grinds or "clicks" into place unless i really baby it/shift slowly. I have read on here that maybe all i need to do is switch the transmission fluid, or should i take it in to have it checked out? maybe i have cluth problems, i really dont know. any recommendations?
Joe.
schmud6 is offline
post #2 of 11 Old 11-08-2011, 06:58 PM
chitownEMT
It's hard to know without actually hearing it. It could be normal shifting noise or it could be a worn out synchro. I have the 4.0L I6 with the 5 speed and it grinds a tad when shifting 1-2, especially when cold. I've been told this is normal because we have "truck" transmissions, meaning a very steep 1st gear. I wouldn't be too worried about it unless it becomes apparently worse. Changing fluid may help a bit, especially if you haven't changed it in a long time or ever. But don't expect miracles, it's just lubrication for the synchros.
-98 Wrangler Sport Chili Pepper Red
|AX15|NV231|D35c Trac-Lok|2" BB|Bushwacker Pocket Flares|31x10.5 GY Duratracs|AR Outlaw II 15x8|Trektop NX|
In the long run men hit only what they aim at. Therefore, though they should fail immediately, they had better aim at something high.
- Thoreau
In the depths of winter, I finally learned that there was, within me, an invincible summer.
- Albert Camus
Disclaimer: The advice given on this forum is free; however, its value may be much less than you paid for it.
chitownEMT is offline
post #3 of 11 Old 11-10-2011, 06:45 PM Thread Starter
schmud6
thanks for the reply. i talked to a friend mechanic. he also said that it sounded like a worn out synchro but it should be fine as long as i dont drive crazy on it.
schmud6 is offline
post #4 of 11 Old 11-10-2011, 10:40 PM
SolarOne
Rather than speculate and coping with it. I would suggest changing the transmission fluid that will eliminate fluid quality, something that is often "forgotten" maintenance. I'd also suggest flushing the clutch fluid via pressurized bleeder, and keeping clean fluid in the reservoir. If its still clicking or the teeth are catching with proper shifting technique. Its more likely to think its the clutch dragging usually being pressure plate or throwout related, when the CMC, lines and slave are in working order.
SolarOne is offline
post #5 of 11 Old 11-10-2011, 11:34 PM
Brewskiskeeter
They all grind in second if you dont shift it right. Do a serach about it and you'll see about 100 other threads about it. My 2000 2.5 manual did it too.
2000 Wrangler 2.5 5 speed
Brewskiskeeter is offline
post #6 of 11 Old 11-11-2011, 07:57 AM
BillStickers
Try taking off the shift boot first. In colder weather the rubber boot can make it hard to get into 2nd gear. I replaced my boot with a cheap $10 one, and now it shifts really smooth.
BillStickers is offline
post #7 of 11 Old 11-11-2011, 08:52 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
That's a common problem with the synchros wearing in the older model Jeeps.Change the gear lube to a better brand and it will help somewhat.My 98' did that and Redline MT-90 helped.It never got worse over the next 2 years before I sold it.
TheBoogieman is offline
post #8 of 11 Old 11-11-2011, 10:51 AM Thread Starter
schmud6
alright so i've decided that im going to switch out the tranny fluid. I was doing a lil research and I found that u should use 10w30 full synth motor oil (because i live in minnesota with brutal winters) and apparently the 10w30 is the new spec for the AX15. anyone have any commentary on experience using the 10w30
schmud6 is offline
post #9 of 11 Old 11-11-2011, 01:43 PM
TheBoogieman
Deeply Disturbed
You have an AX-5 tranny.
3.3 quarts 75W-90 GL3, 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals)
post #10 of 11 Old 11-12-2011, 06:22 PM Thread Starter
schmud6
[QUOTE=TheBoogieman;12486505]You have an AX-5 tranny.
3.3 quarts 75W-90 GL3, 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals)[/
I should use a full synthetic since I live in a colder climater , correct?
schmud6 is offline
post #11 of 11 Old 11-12-2011, 11:13 PM
oakmckinley
Do what boogyman says, use the Redline. I live in MPLS and I used it on my AX-5 and it worked wonders for me. I had a hard time finding it locally. I got some from Courtny truck service in Eden Praire.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
clutch , gear , shift , shifting , transmission
not shifting into 5th gear? justin6808 YJ Wrangler Technical Forum 9 04-05-2007 07:04 AM
Shifting into gear sandman'sjeep YJ Wrangler Technical Forum 5 12-17-2005 02:04 PM
Grindy feeling... Burnunit22 YJ Wrangler Technical Forum 0 11-02-2005 09:50 PM
Grindy Squeaky clutch Jonnyhaku TJ Wrangler Technical Forum 2 09-12-2005 07:33 PM
Grindy AX5... any helping it? Red94YJ YJ Wrangler Technical Forum 1 02-08-2005 05:52 AM
