Quantcast Shifter-Shifter, get your Shifter. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Shifter-Shifter, get your Shifter.
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 04-10-2009, 12:46 AM   #1
CoolContractor
I just spent 30 minutes replacing my automatic shifter handle with an after market one. Works awesome.
2006 TJ Rubicon
CoolContractor is offline   Reply With Quote
Old 04-10-2009, 12:48 AM   #2
CoolContractor
Continued...
2006 TJ Rubicon
Old 04-10-2009, 12:51 AM   #3
CoolContractor
continued...
2006 TJ Rubicon
Old 04-10-2009, 12:59 AM   #4
corndogduff
how'd you get the knob off? ive been wanting to do this....
Duff.
[COLOR="Silver"]98 ZJ 5.9[/COLOR]
[COLOR="Green"]96 ZJ Laredo[/COLOR]
[URL="http://www.jeepforum.com/forum/groups/utah-jeepcrew/"]UT Jeepcrew #13[/URL]
[QUOTE=southerngirl]McDuff ftw[/QUOTE]
[SIZE="5"][URL="www.nightcrew.org"]NIGHTCREW[/URL][/SIZE]
corndogduff is offline   Reply With Quote
Old 04-10-2009, 01:15 AM   #5
CoolContractor
Look at picture #5 in post #1. That is the opening of the shifter handle. There are no screws or nuts holding this thing on. Take both hands, palms up and with the shifter shaft centered between both hands, "pop" the handle upwards firmly. It may take a few tries but it will come off. I was a liitle bit afraid I would break it, but it comes right off. In fact, I removed and installed it several times.
2006 TJ Rubicon
Old 04-10-2009, 01:44 AM   #6
93xjjeep
1993 XJ Cherokee
so the inside of the shifter you put some sort of extra rod or something for the button?? can the new shifter slide down far enuf to bypass the extra piece that you show in the 9 th and 11 th pictures
thanks
BEER...A PITCHER IS WORTH A THOUSAND WORDS..
93xjjeep is offline   Reply With Quote
Old 04-10-2009, 02:00 AM   #7
CoolContractor
The extra piece (green) is a ball point pen tube cut to size. You could use any hollow plastic tube. The handle could be lowered down the shaft if you open up the hole on the lowest part of the new shifter. The shaft is a little bigger than 9/16" and the hole in the shifter was about 1/2". I opened up the shifter with a rat tailed (round) file. The new shifter could be dropped about 3 3/8" if I filed the hole a little more and took out the pen tube. I may play with the height if I don't like it.
2006 TJ Rubicon
Old 04-10-2009, 02:04 AM   #8
Oregun
So the pen is your extenda-button, got it
Oregun is offline   Reply With Quote
Old 04-10-2009, 02:22 AM   #9
ArrizX
1997 XJ Cherokee
Thats awesome and all. But doesnt that put your hand in a kinda funny position to push down the button?
If you live in Washington State, join my Group!
http://groups.jeepforum.com/Washington_State_Jeeps
Check out my current XJ build!
Originally Posted by jeepdavetj View Post
I don't want to live on this planet anymore.
Originally Posted by My Garage
2000 F350 Tow Rig/Daily Driver
1999 F250 2wd Mud Truck project. Divorced Tcase, 3/4 tons and 40s
1997 XJ Cherokee. Cut/Caged, 6" Lift 38s ~Crash Victim~ AKA Thrasher
1999 TJ Wrangler. Retired from DD, 6" Lift on 35s needs overhaul. Project after Superduty
ArrizX is offline   Reply With Quote
Old 04-10-2009, 02:43 AM   #10
93xjjeep
1993 XJ Cherokee
you could cut that lil lip off the shifter and slide it down further? or is 9/16 measured with that lip on it? or a different handle i guess if thats the case right ? i am thinkin on the same idea but i like the shorter shifter makes it easier to use my ash tray in my xj lol ....but i read a few shop manuals saying just pull the shifter straight up but i didnt wanna break it and not get it back on and not work after so thanks you for proving that it just pops off gave me a lil ease of mind with this mission too thanks eh.....hope the pen don't bend on ya
Old 04-10-2009, 03:32 AM   #11
RUBtjICON
Nice job on the shifter handle....But how in the hell do you keep your carpet that clean ?!
2004 TJ Rubicon........My build thread, My URE Vid
www.vanc4x4.net
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline   Reply With Quote
Old 04-10-2009, 10:02 AM   #12
06WranglerX
Haha yea I wondered that too, I been coming across all these clean jeep threads and keep thinking damn I really need to go outside and wash her and vaccume her lol winter sucks...
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline   Reply With Quote
Old 04-10-2009, 10:10 AM   #13
Orvisman
SandSurfer
Orvisman's Avatar
thanks for posting that up... that has been on my mind for some time.. every time I pass the shifter at the auto parts black hole I want to pick one up
2004 Overland 4" KOR/IRO Long Arms
2004 Rubicon 6.5" RK X-Factor LA on 35" KM2s 488s Tom Woods & plenty of BTF Armor ORO U-Turn system
1995 Jeep Orvis 4.0 3" Rancho
www.jeeporvis.com ... www.jeepartist.com ... www.kmaoffroad.org Virginia Beach ... www.obxbreakers.comOff season Jeeper Deals
Orvisman is offline   Reply With Quote
Old 04-10-2009, 04:10 PM   #14
CoolContractor
In the 4th picture, you'll see the unpainted part of the shaft where there is a groove and then paint. The painted shaft is about 5/8" where the unpainted is about 9/16". I didn't want to file the opening to the hole too big at first to push it all the way down in case I didn't like it that low. I am confident that NO plastic tube will be needed if you open up the hole in the new handle drop it all the way down. I'm going to drive it for a while to see if I like it at this height. If not, I will open her up and drop her down. The good thing about this is it can be returned to stock at any time. If you are having doubts if the new one will fit, drive your Jeep to the auto parts store and pop it the stocker off in the parking lot. I had mine off and on no less than 5 times before I mounted the new handle. I remember doing a search on this subject a couple of months ago and some guys are having problems with the plastic (white) piece breaking while in use without ever removing the stock handle. It had left them unable to get their Jeep out of park and into gear. They fixed their problem with a piece of chopstick... yep, a chopstick.
2006 TJ Rubicon
Old 04-10-2009, 04:12 PM   #15
CoolContractor
Picture of metal/plastic piece.
2006 TJ Rubicon
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
