Shifter rattles - JeepForum.com
post #1 of 3 Old 07-03-2005, 01:47 PM Thread Starter
tchfall15
Shifter rattles
I have a 01 manual tj and when i am driving in higher gears, it rattles. It doesnt do it all the time tho. What could that be? Are there bushings or something? How serious is the problem? Thanks
tchfall15 is offline
post #2 of 3 Old 07-05-2005, 08:14 AM
erickpl
erickpl's Avatar
If it happens to the shifter and it is the shifter banging around, you might need a TSB applied.
Check http://www.4x4xplor.com/T-CaseTSB.html. It even has part numbers for you.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #3 of 3 Old 07-05-2005, 09:18 AM
fergyfer
fergyfer's Avatar
That TSB is for the TC case shifter banging against the tub. If it is your tranny shifter vibrating, I'd check your linkage and see if something is loose. It is normal for the shifter to vibrate some.
Green 99 Sahara
OME 2.5", JKS Discos, 31" Dayton Timberline MT's
IPF/PIAA Headlight Conversion
fergyfer is offline
FUN with sqeaks and Rattles drzima TJ Wrangler Technical Forum 4 07-29-2009 10:58 AM
shifter vibrates/rattles PeteSco JK Wrangler Technical Forum 8 03-08-2009 12:19 AM
Cherokee shifter acting as a Short throw shifter?? skyjacked94xj TJ Wrangler Technical Forum 7 02-03-2007 01:42 PM
Glovebox rattles HMTwin TJ Wrangler Technical Forum 3 12-04-2006 11:37 AM
