Shifter Linkage Bushing Failure - JeepForum.com
post #1 of 10 Old 09-16-2016, 09:58 AM Thread Starter
JBeeze
Hello everyone,
Yesterday, my shifter disconnected from my transmission (42RLE) in my 2006 LJ.
After hopping on WF this morning, I went to O'Reilly's and picked up the Dorman Help! #14041 kit of bushings. It supposedly only fits up to the 2005 Wrangler, but I picked it up anyway.
The trouble is, I can't get the damned bushing popped in. So, after hopping back on the forums, I discover I had been reading about shift linkage bushing failures on the transmission side, not the cab side, as mine is. I assume the bearing is the same, but it's impossible to get any leverage because of the shaft in the way. I have read about possibly needing to remove the console to do this properly, but haven't come across a write-up on how to do so.
To worsen the matter, I'm unsure if I'm using the right sized bushing from the kit. I can only get the second largest bearing to fit on the nipple, but it pops back off with any pull whatsoever. It could be that the next size down fits with more leverage/lubrication, or, as I read elsewhere, even the smallest bushing. I'm afraid of using too loose a bushing and having the problem repeat itself.
So,
  1. Do any of these bushings work on 2006s? If so, which?
  2. Do I need to remove the center console to fix it?
I know this is a fairly common problem, so I'm sure some of you, likely many of you, have fixed this problem before.
I would greatly appreciate any help.
JBeeze is offline
post #2 of 10 Old 09-16-2016, 06:02 PM Thread Starter
JBeeze
Tied and True
Update:
First off, I was incorrect, it was on the transmission selector that the bushing failed. It seems obvious now, but so it goes.
Secondly, I could not get any of the bushings to fit. The smallest was very close, I even tried some WD-40, hairdryer, a hammer...no dice. So, I resorted to plan b, and zip-tied it.
Thanks for the great information here on the forums, I would've been lost otherwise!
JBeeze is offline
post #3 of 10 Old 09-16-2016, 10:04 PM
ravenworks
There is a whole thread for this one.
It will involve a trip to Home Depot and about $5 to fix it for ever.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 10 Old 09-16-2016, 10:23 PM
mukluk
How about posting a link to it then?
http://www.jeepforum.com/forum/f9/05...ailure-600665/
http://www.jeepforum.com/forum/f9/05...l#post13255380
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 10 Old 09-16-2016, 10:42 PM Thread Starter
JBeeze
Thanks for the reply!
Admittedly, I'm not too thrilled about zip-ties, even temporarily, so I'll be giving Best4x4's writeup a shot sometime later this weekend.
JBeeze is offline
post #6 of 10 Old 09-19-2016, 08:44 PM
ravenworks
I wasn't at a computer when I replied,the second thread is the one you want
Semper-Fi "81-84"
I.U.O.E. - 18
post #7 of 10 Old 09-28-2016, 06:04 PM
ravenworks
Read this thread the permanent fix is on page 3.
I just did this fix for someone today,total cost about $3.50
Semper-Fi "81-84"
I.U.O.E. - 18
post #8 of 10 Old 09-29-2016, 06:42 PM Thread Starter
JBeeze
UPDATE:
I performed the fix posted by Best4x4 on Monday of this week (9/26/16), the only difference being that I used an angle grinder to remove the nipple's weld on the top side of the bracket, using 1/4" bolt and nut instead of 3/8".
The shifter feels much more solid than it has while I've owned the Jeep (8K miles or so), with no slippage between gears on the selector whatsoever, as there was previously. I hope it holds well, and will report back if I have any issues.
Thanks to ravenworks and mukluk for the help, I appreciate it!
JBeeze is offline
post #9 of 10 Old 10-01-2016, 12:44 PM
ravenworks
Originally Posted by JBeeze View Post
UPDATE:
You need to use the 3/8"s pin and then use a sleeve that goes over the pin along with the two bushings.
From there you will need to drill the cable end a fraction to enable it to accept the sleeve and bushing.
The eye on the cable end will want to walk the way you did it, that's the reason he redid what he originally did.
When that cable breaks it's going to be expensive.
Semper-Fi "81-84"
I.U.O.E. - 18
post #10 of 10 Old 10-02-2016, 06:42 PM
USMCTJ
I bought this, tight fit and much better then Dorman bushing kit. Not permanent like above but should last another 10 years. 👍🏼
http://www.4wd.com/eSearch.aspx?Ntk=...hifter+bushing
USMCTJ is offline
2006 , bushing , linkage , shifter
