Shifter Light..Seatbelt Light..argg...Turn Off....
| Truck-Lite's New LED Headlamp Series | TJ 5.25" Speaker Adapters - NalinMFG | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! |
#1 | |
Very Annoying, I have a 2004 Manual Rubicon, There are 2 things I hate about it, and maybe someone can help me out with this. 1st Problem: the seatbelt light directly in the middle of the RPM and MPH’s. At night time it shine right in my face. Is there a way to turn it off for good? 2nd Problem: the shift light, the jeep is telling me when to shift, I already know when to shift, is their a way to disable that?
Thanks 2004 Rubicon Manual
#2 |
can't say about the seat belt lamp, disconnected mine by disconnecting the wire harness under the seat. the upshift lamp is an LED that can't be removed.
Silver,'04 Sport, 4.0L, 5sp, D30/D44 tracloc, 3.73, F&R disc, 30x9.50, every available factory option, Bilsteins, Hella, Hurst, KC, K&N, RCI Racing, Ram Off Road, Roadmaster tow bar. |
#3 |
Is there a reason why you wouldn't be wearing the seatbelt??
#4 |
Jeep
Yea I know, that seatbelt light goes off when it's connected. I hope you don't drive without it... and if you do you're asking for an early funeral.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#5 | |
Admin, Jeep in Pieces
You can do things the right way or the wrong way. Or you can do it MY way...which is like the wrong way, only faster. Ramsey Winches | My Gallery | www.dakuda.com |
#6 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#7 |
Cut the terminals at the back of the LED?
#8 |
question #1 is easy: buckle your seatbelt
question #2 i'd like to get an answer to myself... |
#9 |
Lifted/Locked/Rolled/Sunk
I agree with others here... just wear the darn seatbelt. It's not a big deal to put it on... second nature for me now. I find myself putting it on just to pull a car around the lot at work
![]() Seatbelts are not uncomfortable either... you just have to wear it a while to get used to it. Actually, I'm uncomfortable anytime I ride in a vehicle WITHOUT a seatbelt!!! As for the shift light... I'm not sure what to say. I guess I'm lucky my '05 doesn't have one, or at least it doesn't work! If that is the case, it's one thing I will NOT be getting repaired under warranty!
I need a 35" tire for spare. PM me if you have something. My Hummer Hole video SIRA 4x4 club I'll be Savvy someday!
#10 |
I wear the seatbelt, and the light still is always on. Has been for some time. I never thought of disconnecting the wiring harness under the seat!
#11 | |
#12 | |
Not wearing a seatbelt is madness in a Jeep. In a severe accident not even the hard top will keep you in the vehicle. Get the belt system performing properly and then worry about #2. Do airbags perform any different if the belt isn't fastened? If the sensor is screwed up you may have more problems than just an annoying light. |
#13 |
Get a gauge cluster from a Cherokee (XJ)...no upshift light
Louisiana 4X4 '97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2 GeauxLook@myJeep |
#14 | |
One thing you can try is adjust the tilt on the steering wheel where it blocks your view of the light, Im 6'5" and the way my wheel sits, I cant see the light unless i move my head a little... so im able to ignore it real easy.. As far as the seat belt light, just buckle up, I myself dont wear my belt much due to being alive after a double rollover that not having a seatbelt saved my life, but I have seen a few wrecks where the driver would have been alive or not hurt as bad if they had there belt on, even though i dont wear a seatbelt much, you wont find me offroad without it..
04 Silver TJ 4" rough country lift 1" currie MML/BL JC fab rockers and 1" seat lift 33"BFG MT's Nth degree adjustable upper arm Nth degree lower arms Power trax front locker |
#15 | |
If the seatbelt light comes on when you're buckled up, the dealer should fix that under warranty.
'03 Bright Silver Metallic TJ Sport BSMCCEP Club Member #45 Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount Next : Jeeperman rear bumper '06 Candy Orange Honda Shadow Spirit 750 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
