Shift Light - JeepForum.com
post #1 of 22 Old 11-02-2005, 02:40 PM Thread Starter
Jeep_Maniac
Shift Light
Here's one for you guys...
I have an '05 SE...I jsut realized that the shift light has not worked since day one. I see the place for it on the instrument cluster, but it just doesn't work. I want to take it to the stearlership to get fixed but I am afraid that since we added factory fog lights, they may void the warranty once they see what is behind the instrument panel...(nothing wrong just doesn't look pretty)...does the SE have this light or no?
Thanks guys!
Daniel
Jeep_Maniac is offline
post #2 of 22 Old 11-02-2005, 02:49 PM
nbf6165
I wish my '02 SE's light didn't work. That thing is annoying as hell at night. If you ask me thats a blessing.
nbf6165 is offline
post #3 of 22 Old 11-02-2005, 02:50 PM
BigJeepJay
BigJeepJay's Avatar
Thanks guys!
Daniel
All Jeeps with 5-speed or 6-speed sticks have the shift light but it is useless…I just pulled the fuse for it so I do not have to see it anymore. Why do you want the light, I mean you know when to shift right?
Pics...
TJ Stretch Thread...
BigJeepJay is offline
post #4 of 22 Old 11-02-2005, 02:51 PM
Jeepin' Rock Cl
I'd rather find out how to break it. It's annoying. It's not even close to accurate anyways as soon as you mod your Jeep.
Jeepin' Rock Cl is offline
post #5 of 22 Old 11-02-2005, 02:55 PM Thread Starter
Jeep_Maniac
of course I know when to shift...but me being the perfectionist I am, I like knowing that all things work but hell, I know what you mean about it at night...(previous car)...
is there a fuse for the light though? Just so I can see if it is in fact broke or blown rather?
post #6 of 22 Old 11-02-2005, 02:56 PM
98JEEPTJ
2005 WK
Like the others I don't see that as a problem. But I doubt the dealership will say anything about your lights you added them to your jeep without hacking into the stock wires correct? I don't really know what you would have in your dash if you are just adding lights. all the wires should be out in the engine compartment with the relays the only thing you would need is one power wire from the switch...
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline
post #7 of 22 Old 11-02-2005, 02:56 PM
frankiefire702
If there is a fuse let me know. So I can pull mine out.
06 tj locked on 36's.
frankiefire702 is offline
post #8 of 22 Old 11-02-2005, 02:57 PM
BigJeepJay
BigJeepJay's Avatar
Nope now that I think about it I pulled the fuse to stop something else in the Jeep. There is no fuse just for this light but Electrical Tape over the light works well.
Pics...
post #9 of 22 Old 11-02-2005, 03:08 PM
Scott_98TJ
I pulled the actual lamp for it from the instrument cluster. Not sure, but I doubt that it's changed over the years. The lamps are small, twist in bulbs and easily pop out. Using this approach, your not potentially pulling power from something else on that fuse.
Taking the instrument panel out is about 10 minute job.... the second time around. It's only like 6 or 8 screws in total IIRC from the start.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #10 of 22 Old 11-02-2005, 04:29 PM Thread Starter
Jeep_Maniac
I mean, I'm not going to worry about it...it's no big deal...I was just curious about it...
post #11 of 22 Old 11-02-2005, 04:39 PM
Bigbob
Bigbob's Avatar
I've never noticed a shift light on my '06. Maybe i need to rev it to 6500 in second or sumthing. I had a shift light in my '99 Dakota and it was about as worthless as a tit on a boar hog. Bob
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #12 of 22 Old 11-02-2005, 06:00 PM
96ExJay
I've always wondered why my shift light doesnt work on my '05, maybe it's a "problem" with all the new Jeeps.
Silver 2005 TJ RME
6 speed, RE 3.5" lift, 33x12.50R15 TrXus MT's, etc.
Gone: 1996 Cherokee Country 4x4, 4.0 HO
96ExJay is offline
post #13 of 22 Old 11-02-2005, 06:17 PM
UAJeep
My light comes on when I am in 5th gear on a 5 speed. I am just to lazy to pull the bulb. Don't fix it you will regret it.
1999 TJ, 4.0, 5 Spd., 3" BDS, 33 X 12.50 BFG A/T, 4.10 gears w/ Truetrac on both ends
UAJeep is offline
post #14 of 22 Old 11-02-2005, 06:21 PM
Rocky529
Rocky529's Avatar
If I'm not mistaken, the upshift light is an LED on a circuit board that can not be removed.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #15 of 22 Old 11-02-2005, 06:24 PM
06slvrrubi
06slvrrubi's Avatar
My 05 does not have a shift light. I seriously doubt that all Jeep's 05-up have a broken shift light. My guess is that they don't have it anymore, but the they didn't want to change the cluster, so they just left the blank in there. I've pulled the bulb's out of all of the shift lights that I've had in past vehicles. I hate them, they're stupid and pointless.
1995 YJ Rio Grande
06slvrrubi is offline
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
Following the Shift Light LandoCommando TJ Wrangler Technical Forum 24 01-16-2008 01:18 PM
TJ Shift Light - In 5th!? hikerpaddler TJ Wrangler Technical Forum 6 11-13-2005 06:03 PM
Shift Light bamajeep YJ Wrangler Technical Forum 5 10-23-2002 02:27 PM
Shift light Ronnie Bravo TJ Wrangler Technical Forum 3 03-17-2002 06:52 PM
