Shift Cable Automatic Transmission - JeepForum.com
post #1 of 83 Old 07-03-2009, 12:16 PM Thread Starter
RHODESIA
Hello I have a question? I had my shift cable break on me not while I was driving but when I put the it in park I then got out of the jeep to get the mail when I got back in I shift it out of park and the shift lever had allot of play in it. in another words I could move the shift lever with out engageing the button on the lever. to make it short it was stuck in PARK. I don't do any "Slap Stick Shifting" like the dealer asked me the other day but I took it to the shop at the jeep dealer all of them were scratching there heads because they have never came across this problem. I own a 2005 LWB unlimited and I don't do any off roading but I do allot of hwy driving, I just put 51,000 miles on her runs great I really like it. so since I do allot of hwy driving is the shift cable going to be a problem in the future? or is this a sign of something else going on? My jeep gets regulator checks ups from the dealer. well what I'm asking it I hate to be out in the middle of the planet and find the cable broke again.
RHODESIA is offline
post #2 of 83 Old 07-03-2009, 12:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's the first I've heard of that particular shifter issue, it's not something I remember ever seeing mentioned here. I really doubt it'll be a problem for you again once the dealer fixes it. Maybe it's a problem on the newer 42RLE transmissions but not on the older autos like I have.
Jerry Bransford is offline
post #3 of 83 Old 07-03-2009, 12:37 PM
chuckv68
I had two different friends have it happen to their Rubicon in the same week, both were '05's. Both were stock and both never wheeled it. One had it fixed under warranty and the other had to pay $300.
chuckv68 is offline
post #4 of 83 Old 07-03-2009, 01:55 PM
otisdog
2008 WK
Here's some things you need to know about your shifter. First one might be your problem. Second one likely will be a problem.
Bushing underneath on cable
http://www.jeepforum.com/forum/f9/gearshift-cable-white-bushing-help-761603/
Broken bead thing - VERY common
http://www.jeepforum.com/forum/f9/can-t-shift-into-park-1st-gear-514108/
How to replace shifter assembly
http://www.jeepforum.com/forum/f9/replacing-gear-shift-assembly-4-speed-auto-pics-552659/
Jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 83 Old 07-04-2009, 03:54 PM Thread Starter
RHODESIA
Thank you all for the information it really helped.
RHODESIA is offline
post #6 of 83 Old 07-05-2009, 07:28 AM
lamcho
I am not alone!!!!
Left me in the middle of the desert one evening!!
A small piece of plastok broke off the plastic thingy that actualy retains the cable in place!!!
Scared the sh*t out of me when kept going with the stick at "P" thanks god the guy infront was fast enough to realise he has to move fast;-);-);-)
lamcho is offline
post #7 of 83 Old 07-05-2009, 08:19 AM
tmwalk
Broken Auto Transmission Cable
Just to let you know I had the very same problem on my 2005 Rubicon Unlimited. The PLASTIC bushing at the transmission linkage disintegrated.
This occured at about 55K miles. The stealership said it wasn't covered under warranty. Couldn't believe the powertrain 7/70K warranty didn't cover this stupid plastic bushing. After paying the dealer about $280.00 I emailed Jeep and they reimbursed me all but $50 as a one-time customer satisfaction issue.
I never heard anyone else having this problem until I saw your post.
tmwalk is offline
post #8 of 83 Old 08-13-2009, 10:15 PM
StockLWBTJ
I just had the same problem with my 2005 LWB TJ. White bushing desinigrated. Had to buy whole cable for $40 for the .05cent broken piece. Dealership quoted repair at $350. This is a very common problem with the 2005 Jeep Wrangler (All automatic trans. models) Tow truck driver that met my wife said that this is the most common problem he faces with this model Jeep. When will this become a recall or class action lawsuit to repair or remburse?
StockLWBTJ is offline
post #9 of 83 Old 08-14-2009, 03:44 AM
Best4x4
My bolt mod has been on there for a while now and I think it's the best thing vs replacing that bushing/cable only to have it fall off again. With my mod I doubt it's going to just fall off or break! And yes when it does happen to you it's a PITA, but a couple of zip ties can get you home safely.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #10 of 83 Old 01-03-2010, 01:23 PM
rubrainded2
Shift cable rention clip repair
Well, today we went to the store, put the Jeep in park, turned off the ignition and went inside. Came out and the Jeep wouldn't go into drive, reverse, etc... stuck in Park. I got under the Jeep, manually shifted it to Drive while my wife held the break. That got us home. Parts store says dealer has to fix with replacement of entire cable. The retaining bushing that holds the cable end onto the transmission shift lever had disintegrated. The cable appears to just need the retaining pin insert to reattach. Temporary(?) fix was a visit to Lowe's where I purchased a rubber grommet (9/16OD x 1/4ID, h#881253) and a Thread Cutting Nut (1/16 Hex, 1/4" stud, H#881219). I pushed the rubber grommet over the retaining pin, then shoved the cable end over the rubber grommet. Then snapped the threaded cutting nut over the beveled end of the retaining pin of the transmission shift lever. The threaded cutting nut was inserted upside down and fit perfectly inside the cable end with the lip of the cutting nut holding onto the cable end. It's holding pretty solid. As a permanent solution, can the cable end insert be replaced without replacing the entire cable?
Before:
After:
Parts:
rubrainded2 is offline
post #11 of 83 Old 01-09-2010, 10:15 AM
UMTiger
Same thing just happened to me. 2005 Jeep Wrangler with 26k miles. Dealer also said this is very common. No recall??? Of course not covered by warranty. Dealership charged $374 to repair. I will contact Jeep to express disappointment.
5/14/2010 UPDATE: I wrote to Chrysler to complain. Much to my surprise, they sent me reimbursement! No letter or explanation, just a check.
Be sure to put your complaint in writing, keep a copy, and enclose a copy of all paperwork that you received from the dealership.
Contact Us by Mail:
Chrysler Group Customer Care
P.O. Box 21-8004
Auburn Hills, MI 48321-8004
Contact Us by Telephone
1-877-426-5337
(1-877-IAM-JEEP)
M-F 8:00 AM - 8:00 PM ET
SAT 9:00 AM - 5:00 PM ET
UMTiger is offline
post #12 of 83 Old 01-09-2010, 11:25 AM
DaleII
Originally Posted by rubrainded2 View Post
Before:
This is what happened to me. Didn't have time to play with it or try to fix it, so I zip tied it to get me moving, then went to the dealer and get a whole new cable for like $32. Hardest part was finding the cable.
2005 Silver LJ
DaleII is offline
post #13 of 83 Old 03-15-2010, 01:26 PM
Zen
I'm in the same boat. I actually picked up the cable this morning before reading best4x4's fix. Next time, and I'm sure there will be a next time, I'll do the bolt "mod".
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #14 of 83 Old 03-15-2010, 02:16 PM
Alawrimore
2005 here also mine has had a zip tie holding it together for at least 2 years now always carry spares just in case.
Alawrimore is offline
post #15 of 83 Old 03-16-2010, 07:05 PM
usjeepers
My Brother's 05 LJ Rubi shifter cable broke. I bought an 05 LJ with 34K on it and the canle is also broken and zip tied into place. I recon I'll go buy a new one one of these days soon.
usjeepers is offline
Automatic transmission shifter cable Zen TJ Wrangler Technical Forum 23 07-26-2013 11:37 AM
Automatic Transmission wont shift ohio_wino TJ Wrangler Technical Forum 15 04-28-2010 10:44 AM
Automatic Transmission Shift Handle Diablosjeep TJ Wrangler Technical Forum 5 04-27-2008 02:13 PM
How do I shift into 4wd with an automatic transmission? jeepidiot TJ Wrangler Technical Forum 6 04-26-2006 09:18 PM
4.0 Automatic Transmission Shift Down rcpeters YJ Wrangler Technical Forum 1 05-19-2004 02:31 AM
