Quantcast Shaking at 55MPH - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Shaking at 55MPH
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 06-28-2001, 07:32 AM   #1
Gage
Shaking at 55MPH
I HAVE A 97 TJ AND WHEN I ACCELERATE TO 55 MPH, AND ONLY 55, ANY LOWER OR ANY HIGER AND NOTHING, THE ENTIRE CAR GOES FROM A SHUDDER, TO A SHAKING, TO NOTHING... DEPENDING ON WHATEVER IT WANTS TO DO. wHAT I CAUSING IT? ANDIS THERE ANY FIX TO THIS PREDICAMENT?
Gage is offline   Reply With Quote
Old 06-28-2001, 04:02 PM   #2
horatio102
Sounds like something is out of balance... Don't know why, but it can have an affect at only certain frequencies... harmonics or whatever. Anyway, check your wheels first. Dried mud caked on the inside? Missing wheel weights? If you don't see anything, pull them off, clean them up, then take your Jeep down to the local tire shop and have them balance all four. If that doesn't solve it, well, then it's going to be more expensive.
horatio102 is offline   Reply With Quote
Old 06-28-2001, 09:12 PM   #3
JONESSJEEP
If the jeep has been lifted at all, or has many miles, the castor angle may be off. If you have a lift and the factory lower frount control arms, they do not provide enough castor angle, this can be fixed by purchasing any number of after market lower arms. If you have no lift at all, the factory rubber bushings may be blown and need to be replaced. If none of this applies to you try a aftermarket steering stabilizer, somthing stronger than your factory one.
98' TJ
Superlift Rockrunner
Jet Chip/Jacobs/Borla hedder & catback....and on and on and on
JONESSJEEP is offline   Reply With Quote
Old 09-27-2001, 10:55 AM   #4
gtpman
Gage I also have a 97 TJ with the exact same problem. Same speed and shaking. If you get it figured out let me know what you found. I'll do the same for you. Maybe I'll try the tire balancing this weekend.
gtpman is offline   Reply With Quote
Old 09-27-2001, 04:41 PM   #5
SunDawg
Is it speed or RPM related? Meaning if you are cruising at 55mph and you feel shaking in 5th gear (or 3rd with an auto), what happens when you downshift and stay at the same speed? Does it keep shaking exactly the same? If so, then breath a sigh of relief, because the solution will probably be the wheels. Of course if you have a lift you have to tell us some details and the scenario may be something like the others have mentioned.
[b][url="http://www.sundawg.net"]S u n D a w g[/url][/b]
'97 Jeep TJ Sahara Edition
-[i]RE 4.5" Lift[/i]
-[i]BFG KO 33x10.5r15 on AR-767 15x8[/i]
-[i]Tom Wood's Conversion Kit[/i]
SunDawg is offline   Reply With Quote
Old 06-05-2002, 05:10 PM   #6
Paul DK
Don't know if have fixed it yet, but I had this problem after mine had been in an accident and the transmission mount was broken. I replaced that and it works fine.
Paul DK is offline   Reply With Quote
Glock Forum
