Shakes really badly - JeepForum.com
post #1 of 5 Old 06-11-2009, 08:40 AM Thread Starter
davenjit
Shakes really badly
Ok, so i have a 2004 Rocky Mountain Edition...when i hit some bumps in the road my front end begins to shake uncontrollably. I have 31'' BFG AT's that have about 40,000 miles on them. I just rotated my tires and it seems that its getting worse. I need to pull over and slow down to well under 30 MPH. about 3 years ago this started to happen for the first time which led to me buying the BFG's. My machanic told me that i needed new tires. However the tread on the BFG's don't look awefull. IDK maybe i'm wrong as i'm not great at this stuff, however it just doesn't make that much sense to me.
If you have any suggestions as to what else could be causeing this (or wanna call me dumb cause its obvious and i'm just stupid) please let me know what you think.
Thanks.
Dave
davenjit is offline
post #2 of 5 Old 06-11-2009, 08:47 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Have you had an alignment recently.The toe in being off can do that.
TheBoogieman is offline
post #3 of 5 Old 06-11-2009, 08:47 AM
03rubiconMG
this is a pretty basic case of death wobble. rotating the tires can change this because if the rear tires were balanced worse than the front then that will increase DW. start by getting under your jeep and making sure all of your control arms and track bar in the front end are tightened well along with anything else you can see.
my track bar bolt was loose which was the main cause of this.
then jack up each wheel and check to make sure your ball joints are still good by putting one hand on top of the tire and one hand on the bottom and try to move the top and bottom in and out, they shouldnt move at all.
If this does not work go to a good tire place and have the wheels balanced. this was another cause to some death wobble i had.
Take the jeep to an offroad shop that does tires also they tend to be better at balancing tires in general and can help you with any other ideas.
one final thing it could be is the steering stabilizer but probably not, dont buy anything new unless you have to.
2003 white rubicon on 37s
03rubiconMG is offline
post #4 of 5 Old 06-11-2009, 08:48 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
search death wobble.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 5 Old 06-11-2009, 08:50 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Sounds like death wobble. Check all of your front suspension and steering. Look for loose/worn tie rod ends, ball joints, hub bearings, etc. Pay close attention to your trackbar ends, make sure they are tight and not worn. Make sure all the nuts/bolts are tight. If all that checks out go for an alignment and tire balance. That should cover what may be causing your issue. You can also do a search here and find numerous threads about death wobble and how to fix it.
Here are the results of one search.
http://www.jeepforum.com/forum/searc...archid=5117198
Don't run out and buy a steering stabilizer thinking that will fix it. If your front suspension/alignment is good you should not have DW without it.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
Need Help Badly Trytan74 YJ Wrangler Technical Forum 18 07-26-2009 07:45 PM
wrangler shakes badly with little braking at 50 Wishmaster22 TJ Wrangler Technical Forum 3 07-05-2008 08:19 PM
New guy here. Need some 4.2L help, badly. 1stuckdude YJ Wrangler Technical Forum 15 02-11-2008 06:42 PM
Need help badly!!!! 12345 YJ Wrangler Technical Forum 6 01-30-2007 01:22 PM
need help badly JYRUS YJ Wrangler Technical Forum 9 10-26-2001 12:12 PM
