Shakes 55-60mph - JeepForum.com
post #1 of 18 Old 10-25-2007, 08:03 PM Thread Starter
SportTJ4x4
Shakes 55-60mph
My 2004 Sport has been shaking around 55-60 mph when i got above 60 its fine and below 55 its fine. i can mostly feel it in the steering wheel. I installed a new steering stabilizer thinking that may help, no difference. Nothing feels loose in the steering so i don't think its tie-rod ends or the steering box. You guys have any ideas?
SportTJ4x4 is offline
post #2 of 18 Old 10-25-2007, 08:09 PM
tjaaron
Tire balance? I had the same problem, only it was between 45-50 mph it would shake like no-body's business. Then i bought new tires, the installation guy told me the wheels were really messed up and needed a lot of weight. Now it rolls like a dream.
tjaaron is offline
post #3 of 18 Old 10-25-2007, 08:11 PM
cmoore
cmoore's Avatar
probably tire balance. check to make sure your track bar is tight though. Search "death wobble"
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline
post #4 of 18 Old 10-25-2007, 08:21 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Check tire pressure weekly, balance and rotate religiously every 3K. GSA tires are prone to this issue. Mine always came back shaking when I reached 2500 miles after balancing.
There's something causing this across Jeep Wranglers -- just tooo many Jeepers experience this.
I've moved onto MT/Rs and have less of this issue, but very very slight shakes occur at 70mph. When I balance & rotate it will go away, only to return in about 3K.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #5 of 18 Old 10-25-2007, 08:33 PM
thejafe
thejafe's Avatar
I was having death wobble between 40-50mph -- until I got an alignment. Might want to look into that.
thejafe is offline
post #6 of 18 Old 10-25-2007, 08:35 PM
jmreagan
jmreagan's Avatar
Good advice! Keep them rotated correctly. Make sure they are balanced 0 to 0. Meaning PERFECTLY BALANCED. Almost is not good enough. Tires sometimes sling weights off. Make sure your frame side track bar is tightened to 55ft pounds too. If that doesn't take care of the shimmy check your alignment specs and make sure it it between 1/8 to 1/16 toe in. Unless you have badly worn tires or have broken a band this should fix your shimmy. Good luck!
03' Sport, 4.0L, 3.73, 5 speed, D44/D30, 3 inch coil/shock lift, RE track bar, Tera disco's, 35x12.50's Dunlap Mud Rovers MT's, Spidertrax spacers, Viper 5000 alarm, Tuffy console, LOD extreme bumper/tire carrier and front bumper, A-Z rockers, AA SYE, Tom Woods DS, JKS Rear UCA's.
Originally Posted by KKiowaTJ
Sorry master, Dont whips me, I's do betta next time..
jmreagan is offline
post #7 of 18 Old 11-13-2007, 02:41 PM Thread Starter
SportTJ4x4
So i went to the tire shop today and got my tires balanced and rotated no difference, so what should i try next?
post #8 of 18 Old 11-13-2007, 02:49 PM
CCJ
My 99 sahara would always do it whenever I'd breach 80mph or hirer. I always assumed it was a wind resistent thing.
CCJ is offline
post #9 of 18 Old 11-13-2007, 03:09 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Alignment doesn't cause shaking so I'm still thinking tires. Not all tire shops give a crap about getting tires balanced as perfectly as they need to be on a Wrangler. There have been some balancing jobs I've had done where it took three attempts to get it right so I had no more shimmy/vibration. That was with Discount Tires. The third time, they put it on a different balancing machine which I seem to recall it being called a "Ride Match" balancing machine which finally did the trick.
Getting
Jerry Bransford is online now
post #10 of 18 Old 11-14-2007, 12:13 PM Thread Starter
SportTJ4x4
Well is this a problem with the Goodyear GS-A, or it happens with all tires on jeep wranglers
post #11 of 18 Old 11-14-2007, 12:34 PM
Jerry Bransford
Administrator
It's certainly not specific to any particular tire, it even happened to my MT/Rs. It's more just what can happen to any tire... wear unevenly through lack of rotation, weights getting knocked off & the tire wearing unevenly afterwards, road damage, trail damage, not rotating the tires as often as needed, etc.
Getting
post #12 of 18 Old 11-14-2007, 12:35 PM
BigGillyStyle
BigGillyStyle's Avatar
I have 30" GS-As and had this same problem at ~55MPH. The whole front end shook horribly. This immediately followed me rotating my tires myself (and I obviously did not balance them). Since some tires that were on the rear moved to the front...BINGO, the problem surfaced. To the original poster...did this behavior occur right after a tire rotation? If so, I'd say that even though you got them "balanced", they didn't do a proper job. In my situation, a balance at Discount Tire immediately fixed the problem.
Rocky Mountain Edition Club, Member #3
BigGillyStyle is offline
post #13 of 18 Old 11-14-2007, 02:37 PM
Garrett63
I had this for so long!! it happend to be my steering stabalizer. wasnt beefy enough once i replaced that the wobble went away. i used to have the wobble at 38-40 once i hit 41-41 it went away but then later it did it passed 60mph then i didnt drive untill i figured it out. took it in to get tires rotated and balanced also got an alignment but replacing the steering stabalizer fixed it 100%.
Garrett63 is offline
post #14 of 18 Old 11-14-2007, 02:39 PM
.Jch.
.Jch.'s Avatar
Unbalanced tire tread can do it too. I had to use my spare up front for a while (it had significantly less tread) and I'd get a rough shake in the 50's for a small stretch. Went away as soon as I got my new tire.
_____
l JEEP l
OllllllllO
2006 Unlimited
Black Jeep Club V2.0 Member #2006
.Jch. is offline
post #15 of 18 Old 11-14-2007, 02:43 PM
Dravintoad
Dravintoad's Avatar
You have only masked your root problem by installing your steering stabilizer. As stated above, you need to have your wheels PERFECTLY balanced
Nothing to see here.
Move along.
Dravintoad is offline
LJ shudders from 50-60mph LJforG TJ Wrangler Technical Forum 2 01-08-2010 12:06 AM
Vibrations at 60mph mcg TJ Wrangler Technical Forum 6 04-04-2007 03:37 PM
Bad Shaking at 60mph tcestes TJ Wrangler Technical Forum 2 10-29-2006 08:57 PM
Shaking between 56 and 60mph... 4x4Dogg TJ Wrangler Technical Forum 25 10-13-2006 01:13 PM
Shakes at 60mph sentinal02 YJ Wrangler Technical Forum 2 05-15-2004 01:20 AM
