Shakes - JeepForum.com
post #1 of 6 Old 03-15-2007, 02:30 PM Thread Starter
Feigle
Shakes
I have 2 1/2 inch susp lift with a 1 inch Bl
After i put the 1 inch BL on I put on 33.1250 swampers.
When I get over 60 I get some vibes??? The BL should not casue that right. More than likey the tires is what I was thinking I took them down and had them rebalanced. Everything checked out fine. Dealer says they need to wear down a bit before they smoothen out. I have about 800 miles on the new tires. Could this be in fact the tires and not something out of whack.
Feigle is offline
post #2 of 6 Old 03-15-2007, 02:39 PM
Crashnburn80
Crashnburn80's Avatar
The BL won't cause the vibes but the suspension lift will. You can do a MML or a Tcase drop to get rid of them. As per the tires, I have heard that swampers dont balance well, but I don't think thats your issue.
Crashnburn80 is offline
post #3 of 6 Old 03-15-2007, 02:42 PM Thread Starter
Feigle
Well I bought the jeep with the susp lift and 32's I only added the 1 inch Bl and 33's.
before the lift and tires it did not have the shakes at 60 like it does.
Feigle is offline
post #4 of 6 Old 03-15-2007, 02:46 PM
mdm
Farm Wheeler
It could be drive shaft vibration but I would suspect the tires are the problem. If you have access to another set of tires you could swap them out and see what happens. You could swap your front and rear tires. Tire problems are usually felt more in the front than the rear. You could also remove the rear drive shaft and drive in 4HI and see if you still have the vibration.
mdm is offline
post #5 of 6 Old 03-15-2007, 03:02 PM
Crashnburn80
Well if it didn't vibrate before with the lift, and the only thing that changed was tires and BL, then I would suspect the tires. The BL will not cause vibes.
post #6 of 6 Old 03-15-2007, 03:04 PM
mdm
Farm Wheeler
Opps - overlooked "BL" - disregard previous statement. It's been a looong day.
mdm is offline
TJ with the shakes Dalke-cj TJ Wrangler Technical Forum 2 09-30-2008 06:54 AM
Yj shakes J-Rad YJ Wrangler Technical Forum 6 03-20-2008 07:55 PM
Help with the shakes! younixguru YJ Wrangler Technical Forum 3 07-25-2006 12:03 AM
got the shakes tat2freke TJ Wrangler Technical Forum 5 11-29-2004 03:14 PM
the shakes Katch TJ Wrangler Technical Forum 8 11-18-2003 09:55 AM
