Severe wobble and vibration issue after lift. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Severe wobble and vibration issue after lift.
Bds fox ipf 2.0 racing series shocks now available at rockMemorial Day sale on Artec - free shipping thru end of MayRIGID INDUSTRIES LED Lights and Kits. Dually, D2 & E-S
Unread 03-11-2007, 03:08 PM   #1
Libtekguy
I just had a 2" Sping lift put on my 2003 TJ yesterday. I drove about 50 miles home from the dealer that put them on. No Problems. Today, I get out on the highway and after about 10 minutes of driving, my jeep starts wobbling and vibrating like an earthquake. I pull over, inspect everything I can. I don't see anything broken. Nor does anything feel loose. I get back on the highway and drive on to my destination with no problems. Then later in the day on my way back home, it did the same thing. I happened when I was going about 65 mph. What I don't get is that I drove on the highway for an hour yesterday with no problem, and now it's freaking out.
Any suggestions? I havn't called the dealer that put it on because they are closed on Sundays. Could it just be wheel alignment? or is something installed wrong or broken? I don't think drive shaft length would be an issue with just a 2" kit. HELP!
Libtekguy is offline   Reply With Quote
Unread 03-11-2007, 03:30 PM   #2
stedwest
It could very well be, just an improper toe setting. You should have about 1/8" of toe-in. After that, any number of loose parts or bolts could cause 'death wobble'.
With only a 2" lift, I doubt the front trackbar was modified, and that is a frequent culprit. I would think a trip back to the shop is in order.
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline   Reply With Quote
Unread 03-11-2007, 03:51 PM   #3
STW
You can search on "death wobble" for more ideas on this. But I had the same thing a couple years ago and getting the tires re-balanced solved it completely. According to what people post on the DW threads, that's what's wrong the majority of time people have this problem.
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline   Reply With Quote
Unread 03-11-2007, 08:28 PM   #4
BFG Man
Make sure they max out the camber. That will make it shake.
Wait and see...
BFG Man is offline   Reply With Quote
