several problems since my re 4.5 lift install - JeepForum.com
post #1 of 7 Old 05-24-2005, 07:45 PM Thread Starter
incubus2012
mainly the death wooble. it was undriveable until i had it aligned, now the dw happens when i hit big bumps, usually always on an incline with a curve like a freeway ramp. what can i do. i checked to see if my control arms are tight and i can slightly turn the upper passenger with my hand. it seems like i cant get it tight enough, i assume the bushing is bad but it looks ok. how would i even replace that one since its on the axel? and i noticed this today, could this be the cause?
if there is anyone here close to jonesboro, ar that could look and maybe help me please pm me
incubus2012 is offline
post #2 of 7 Old 05-24-2005, 08:51 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
Bad ball joints can cause that. Also a loose front track bar, and out of balance wheels, will cause it
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
Jeep Pics
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #3 of 7 Old 05-24-2005, 08:53 PM
got4-Lo
balance ur tires. and tighten ur track bar when it connects to the axle
stretched *** tj
webwheeling.com
got4-Lo is offline
post #4 of 7 Old 05-24-2005, 11:49 PM
RockPaws
RockPaws's Avatar
One trick I use in troubleshooting front end problems, is to have a friend turn the steering wheel back and forth about 1/8 to a 1/4 turn. While they are doing this inspect the steering for abnormal movement like the track bar, steeing linkage, etc..
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
www.redrock4x4.com Rocks!
Need Him?
RockPaws is offline
post #5 of 7 Old 05-25-2005, 12:10 AM
Baas
Baas's Avatar
I think you are right. There is no ONE thing that will cause DW. I say this because a lot of people blame only a loose track bar. Now I know a lot of you are going to call this BS but. I travelled 8 miles without a front or rear track bar in a friend's newly lifted ZJ.
With NO DW.
I must admit it was quite a task. I had to turn the steering wheel a full turn before the Jeep started turning.
This Jeep had a DW before we installed the lift. The kit was a RE 3.5 lift. I suspect that the lower CA's rubber bushings were shot. The DW only occured when bracking in a turn.
Now for the reason why I travelled without the Track bars. We had an alignment shop install the lift but the rear track bar bracket and the front track bar was for a LHD Jeep. I had no choice but to drive it back to our workshop and do some fabbing work.
You should look at each component sepperately one at a time. A lift just amplifies any dormant problems.
As for the upper control arm rubber. Currie manufactures a Johhny Joint weld on replacement.
I want mine replaced with that as well.
04 Sport
4" Currie lift with Anti-Rock
Rock Krawler 4 link rear
Skyjacker 2" body lift
Safari Snorkel
35" Procomp X-terrain
Mickey Thompson Classic lock
Aussie locker front & rear
4.88 gears
CV Drive shaft
4WD SYE
215 Ponies I6
Baas is offline
post #6 of 7 Old 05-25-2005, 03:01 AM
jerod2099
I won't call BS on that. My 87xj front track bar ball joint thing is so worn out it is about to fall off. I can tell it is bad because we watched it while someone turned the wheel back and forth and I can feel it sort of kick over to one side or the other as I turn but even with a 3" lift (homemade and crappy) with 32's (used and crappy) I have NO DW. My tires are balanced and we aligned it with a tape measure. If the trackbar was such a POS for causing DW all the time I would have DW but I don't. I have seen hoes on corners that weren't as loose as my track bar is.
jerod2099 is offline
post #7 of 7 Old 05-25-2005, 11:06 AM Thread Starter
incubus2012
anyne close to jonesboro, ar?
Lift Install Problems.... Unlimited04 TJ Wrangler Technical Forum 22 04-20-2010 05:43 PM
lift kit install problems... jmkeo74 TJ Wrangler Technical Forum 6 02-23-2008 03:00 PM
Problems with lift install No Fear Jeep TJ Wrangler Technical Forum 3 06-16-2007 02:34 PM
List your problems with lift kit install Snuffster TJ Wrangler Technical Forum 11 09-24-2006 04:44 PM
More Problems with Lift Install rjkjoe TJ Wrangler Technical Forum 11 09-25-2005 11:13 AM
