Quantcast Setting Up Bump Stops - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Setting Up Bump Stops
Old 06-08-2008, 02:47 AM   #1
Wallace
Ladies and Gentlemen - Please excuse the "nub" question.
But... how do you all go about setting up your bump stops? Is there anything in particular i need to know? I have just finished installing the TnT long arm kit into my TJ and want to make sure I don't rub on the fenders at full stuff (have mashed them up previously).
What's the "best" way to go about setting up the bumpstops, is there something in particular i should buy (JKS adjustable bumpstops or somethign to that effect) to make my life easier?
Thanks.
2000 TJ Wrangler Sport
Half Door - Soft Top
WARN Rock Sliders, 4.5" RE Springs
TnT Customs Dual Triangulated Long Arm Lift, NV4500
35" M/T Baja Claws, TBT Rear Bar with Tyre Carrier
ARB Front Bar - Dual Hella 4000 Spotlights.
Wallace is offline   Reply With Quote
Old 06-08-2008, 03:48 AM   #2
MQ79
Use hockey pucks. Just drill a hole through the center of them and then drill and tap the coil bucket. Stack as many as you need.
MQ79 is online now   Reply With Quote
Old 06-09-2008, 04:57 AM   #3
Wallace
thanks mate -
how do i know how many to stack though? what's the best way to find this out?
Old 06-09-2008, 08:32 PM   #4
jrtdogbone
Your best bet is to make a good estimate and install them. I went to a loading dock area and ran my Jeep up the cement wall and got out and checked the fenders as I went. I needed to add about an additional 1/2" of stop.
You needed to drill and tap the lower coil bucket before you installed the springs, that way you can add or subtract without removing your springs every time.
Hockey pucks work good, you can even use gasket sealant to hold them in place until you remove the springs and drill and tap the spring coil buckets. I ran for a year and half like that before I removed the springs and drill and tapped them.
Good Luck
The Dog
The Dog
2004 Jeep Willys
http://jeep-willys.com/
jrtdogbone is offline   Reply With Quote
Old 06-09-2008, 10:00 PM   #5
mferrari
DelmarvaOffroad.com
mferrari's Avatar
No need to drive anywhere and test... Use a jack and raise the axle to the point you want the tire to stop. Then look at the bump stop and guage how much you need to add..
Michael Ferrari
TJ Based Buggy <BUILD THREAD>
Team 120 - DOR Racing - Racing for Operation Homefront
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Delmarva Offroad
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline   Reply With Quote
Old 06-10-2008, 04:34 AM   #6
Wallace
ok cool - thanks.
P.s - Mferrari - that is one hell of an air horn.
Glock Forum
