Service? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Service?
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 05-18-2014, 08:55 PM   #1
Nick01234
Service?
Hello, this is my first post on a jeep forum!
I recently bought a 1997 wrangler with the 2.5L motor. It only had one owner and he kept in a garage so it is pretty clean. It has 150,000 on the odometer and I am just curious as to what fluids and filters should I change? Also what should I expect to break/ need replacing soon? I replaced the belt yesterday and have to order a new pressure unit but other than that it seems to be a pretty solid vehicle.
Thanks!
Nick01234 is offline   Reply With Quote
Unread 05-18-2014, 10:13 PM   #2
geroux
Unless the PO provided detailed and what looks like reliable maintenance/service records, I would do everything. Motor oil/filter, tranny fluid, TC fluid, diffs fluids. Coolant flush and fill. Brake fluid flush and bleed.
Check your brake pad/shoe and rotor/drum wear. Check U-joints.
Just off the top of my head, I'm sure I'm missing something...
geroux is offline   Reply With Quote
Unread 05-19-2014, 12:51 AM   #3
robncar
We Got The Cup, AGAIN!!!
robncar's Avatar
Just curious... what color is your jeep? Any pics?
robncar is offline   Reply With Quote
Unread 05-19-2014, 06:29 AM   #4
Nick01234
Its red, it is stock a the moment but I plan to do a couple things. I'll try and put up a pic later.
Unread 05-19-2014, 06:42 AM   #5
JBTJ
JEEPer For Life
JBTJ's Avatar
If unknown, then ALL fluids. Fluids are the key to a long happy JEEP life. Just ask my 1980 CJ7 with 365k on the clock.
JBTJ is offline   Reply With Quote
Unread 05-19-2014, 07:48 AM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Serpentine or timing belt? Replace the timing belt if you don't know when it was replaced.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
Originally Posted by Jeepsr4me View Post
Yeap its your nuts that giving you the trouble here...... Get the right ones
TheBoogieman is offline   Reply With Quote
Unread 05-19-2014, 08:48 AM   #7
Nick01234
I replaced the serpentine belt, but it probably isn't a bad idea to do the timing belt also. I do not have any information on previous maintenance so I will go ahead and change all the fluids and filters. The rpms and oil pressure fluctuate a little bit, could this be happening due to the fact the oil pressure sending unit is leaking oil?
Unread 05-19-2014, 08:55 AM   #8
JBTJ
JEEPer For Life
JBTJ's Avatar
Oil pressure, yes. Not RPM's though.
Unread 05-19-2014, 10:25 AM   #9
JBTJ
JEEPer For Life
JBTJ's Avatar
Thanks!
Got any pics of your JEEP?
Unread 05-19-2014, 09:26 PM   #10
geroux
My '04 FSM shows the 2.4L has a timing belt. But I'm about 98.5% sure the '97 2.5L has a timing chain based on these threads below. Look into that before you go by a timing belt.
If it's a chain don't worry about it unless you have timing problems or hear clanking.
http://www.jeepforum.com/forum/f9/timing-belt-1386743/
http://www.jeepforum.com/forum/f9/ti...-4-cyl-352332/
Unread 05-19-2014, 10:08 PM   #11
Dave02TJ
Dave02TJ's Avatar
Correct, but you are not forum supporter, so why should he take your word on it? LOL just kidding.
To the OP: Like the others said, do the basic maintenance and go from there.
Dave02TJ is offline   Reply With Quote
Unread 05-19-2014, 10:11 PM   #12
Rangerz
Rangerz's Avatar
Fluids, belts and hoses. I did this on mine. That way I knew the status of everything.
"Jeeps Love Gas Stations"
Chris - Lost Wages, NV
2002 Dodge Ram 2500 Diesel, 2009 Lance 825, 2005 TJ,
Polaris RZRs.
Rangerz is offline   Reply With Quote
Unread 05-19-2014, 10:19 PM   #13
geroux
That sarcastic signature has been gone for maybe over a week! It will follow me forever.
Unread 05-19-2014, 10:27 PM   #14
Dave02TJ
Dave02TJ's Avatar
LOL I liked it, but i'm goofy that way.
OP: Take a look at all the u-joints too
Unread 05-20-2014, 09:54 PM   #15
geroux
Thought of another... Spark plugs and air filter.
Basically, unless you have complete and reliable service records, as stated before, do everything and start your service intervals over.
