serpentine belt - JeepForum.com
post #1 of 4 Old 07-20-2010, 09:04 PM Thread Starter
Utfan010
serpentine belt
i need to get my serpentine belt off to move around some pulleys and check all of them cause im having some extremely high pitch noises from the belt drive that start when i start the jeep up and get louder as the the RPM's rise. so can anyone let me know the easiest way to remove the belt and put it back on?
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 4 Old 07-20-2010, 09:09 PM
asjeep
I think there is a pulley on the belt that is the tensioner... put a wrench on it and it removes the pressure on the belt.... then take the belt off.... i think i have the same issue right now.... bet it's your idler pulley.... it usually is for some reason
2002 TJ SE
asjeep is offline
post #3 of 4 Old 07-20-2010, 09:12 PM
freeskier93
The idler pulley under the power steering pump is the tensioner pulley. To remove the belt you loosen the bolt on bolt on the tensener pulley, don't remove it, then there is a long bolt behind the pulley that moves it down and loosens the belt. Kinda hard to explain, but see if someone else has a diagram.
freeskier93 is offline
post #4 of 4 Old 07-20-2010, 09:13 PM Thread Starter
Utfan010
thats what i was thinkin too, i removed the idler pulley from the top next to the alternator but it was perfectly fine but im gonna check the bottom right one tomorrow i just wanted to know how to take the belt off and on incase worse comes of it
Utfan010 is offline
belt noise , belt tensioner , pulley , rpm , serpentine belt , TJ
87 YJ serpentine belt 258 WITHOUT AC jeepguy85 YJ Wrangler Technical Forum 16 11-06-2012 03:09 PM
R&R Serpentine Belt timinfla2 TJ Wrangler Technical Forum 2 09-08-2009 07:39 PM
Serpentine Belt Help RLD831 TJ Wrangler Technical Forum 3 06-27-2008 09:59 PM
Serpentine Belt ???? pkp190 TJ Wrangler Technical Forum 5 04-17-2005 05:29 PM
Serpentine belt R&R Vetteman YJ Wrangler Technical Forum 1 08-28-2003 07:16 PM
