serp belt tensioner stuck? - JeepForum.com
post #1 of 4 Old 12-22-2010, 02:36 PM Thread Starter
Utfan010
i was trying to locate a squeal from the belt assembly earlier today when i took the belt off i lubed up the idler pulleys and was going to put the belt back on when i noticed that when i would turn the tensioner bolt it would not move AT ALL it is just stuck i had a cheater bar and a whole can of pb blaster on it and came back and still would not move. what id recommended i have the 2.5L 199 SE, i did get the belt back on but it was an hour long process and i did not get the squeak to go away either, but im still concerned about the tensioner..
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 4 Old 12-23-2010, 08:26 PM
Rubicon_Rob04
How exactly did you get the belt off and on?
The idler pulley bolt or the adjusting bolt wont turn?
Not trying to be a smartass but you do know you loosen the bolt at the idler pulley a couple turns and then use the long worm bolt to adjust the tension.
Rubicon_Rob04 is offline
post #3 of 4 Old 12-23-2010, 10:26 PM
MO2500
The tension adjuster on my '97 2.5 was stuck just as bad. I soaked it with PB for hrs and I believe I ended up putting a 1/2" impact on it and when it finally came loose I thought I broke something. And after working on it for 2+ hr's i probably would have been fine with the adjuster breaking so i could just replace it You have to loosen the idler pulley bolt a few turns if you don't already know before you can turn the adjuster.
Once you do get it free, run the adjuster up and down the bolt with anti-seeze several times so it doesn't stick again. Mine works smoothly now
Instagram: @omsmike
MO2500 is offline
post #4 of 4 Old 12-25-2010, 09:59 AM Thread Starter
Utfan010
alright i saturate it in pb blaster and break out the impact haha, but no i did loosen up the ider pulley quite a few turns but the adjuster bolt it seized up inside of the block where th idler pulley screws into. and me and my dad and a friend man handled the belt back....pretty tough to do.
Utfan010 is offline
serpentine belt , squeak , tensioner
Manual belt tensioner question... missing tensioner bolt? JFamily TJ Wrangler Technical Forum 22 03-23-2016 10:13 AM
New belt tensioner but my belt is still loose 02tjsport TJ Wrangler Technical Forum 4 02-26-2009 11:33 AM
What serp belt? samsonitesamson YJ Wrangler Technical Forum 11 08-14-2008 06:41 PM
serp belt yj 88 YJ Wrangler Technical Forum 4 08-14-2008 08:28 AM
HELP. serp. belt drew76924 TJ Wrangler Technical Forum 3 05-29-2005 03:19 PM
