Sentry Key Replacement Options (I only have 1 key!) - JeepForum.com
post #1 of 39 Old 02-17-2008, 08:45 AM Thread Starter
Boilermaker52
BO1LER UP
Boilermaker52's Avatar
When I got this Jeep (2002 TJ) it only came with 1 key. I didn't think it was a big deal. Well I received one of those rock keys that has the chip in it but when I read my manual about reprogramming it says I need two keys.
Can you program it with one? Has anyone tried?
How much does the dealership charge to cut/program a key (can they even do it with one) ?
I'd like to make one trip to the dealership to get it cut if I can program it myself!
Oh yeah, I tried searching and didn't find anytihng specific...
'02 TJ Sahara, 2"BL, 33" MTs, RE SF 3.5, AA SYE, TW DS, Rokmen Mercenary Front Bumper, Warn 9.5ti, Cobra 75WXST
Boilermaker52 is offline
post #2 of 39 Old 02-17-2008, 08:54 AM
2jhanna
the not having 2 keys is going to be your killer. you will have to get help (dealer) to get it programmed.
i also got a `02 last year, but got 2 keys. i ordered a blank from ebay and a guy at lowes cut it for me FREE. then i was able to program it myself, again it takes 2 keys to do it yourself.
i have heard (but not confirmed) that some locksmiths may have what is needed to program the computer.
jhanna
denton county, tx
2jhanna is offline
post #3 of 39 Old 02-17-2008, 09:03 AM
rubiweeler
The locksmith that we go to for work can program keys with only one, they have a computer thing they hook up to it, probably the same thing the dealer does. It still costs almost $90 to have them do it though.
Its gonna be expensive either way you go.
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline
post #4 of 39 Old 02-17-2008, 09:34 AM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Stealership is your only option.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #5 of 39 Old 02-17-2008, 09:41 AM
BYuen
BYuen's Avatar
Yea, Im in that same boat... So far I've just been praying I'll never lose my one key...
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is online now
post #6 of 39 Old 02-17-2008, 10:03 AM
djt283
djt283's Avatar
You could just disable it, at least for the time being. Just tape or zip tie your key inside the dash somewhere (or cut off the head so you don't leave a key in there). Then any key will work.
djt283 is offline
post #7 of 39 Old 02-17-2008, 05:57 PM
Bigbob
Bigbob's Avatar
Buy 2 keys and have them cut. Then go to the dealer and have him program them. If you have 2 keys you can do it, but with one key it is a no-go. I had a key made and programed at the dealer for about $50.00. Store the 3rd key in a safe place.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #8 of 39 Old 02-17-2008, 06:11 PM
2jhanna
i agree with having 2 extras, have the dealer (or locksmith) program 1 key. then with your original and the dealer made copy, you can program your 2nd new key. this way if you lose 1, you will still have 2 for the next time.
according to the manual, the computer can recognize 8 keys. i don't know if this is a total of 8 in its lifetime, or 8 at any given time. either way, you still should be well within the 8 limit.
jhanna
denton county, tx
2jhanna is offline
post #9 of 39 Old 02-17-2008, 06:42 PM Thread Starter
Boilermaker52
BO1LER UP
This sounds like a good plan, so it is impossible with one key? Has anyone tried to simply re-insert the one key twice? Each key gets a unique code??
post #10 of 39 Old 02-17-2008, 07:00 PM
2jhanna
I will try to explain it the best I can and in the simple terms as I understand it. If anyone wants to correct any mis-statements or add any info, feel free.
It is kind of like "rocket sience". Each key has a unique transponder. When you insert the key into the ignition, a device inside the steering column, near the igniton switch, emitts a current signal, this signal actualy creats a voltage/power source inside the key, which excites the transponder inside key to also emitt (or transmitt) a unique signal/frequency back to the device in response. This signal is then read by the device's reciever which feeds it to the computer. The computer can store in its memory, the unique frequency responses for up to 8 keys. If it recognizes the key being used, it will allow the car to run. If it does not recognize the frequency from the key, it will shut down the engine.
How did I do ??
You do need 2 keys to do it yourself. There is a write-up in your owner's manual. My son had a `98 explorer with the same system. We also bought a 3rd key (and programed it) for that when we first got it.
jhanna
denton county, tx
2jhanna is offline
post #11 of 39 Old 02-17-2008, 08:23 PM
MontyTJ02
WOAH What dealer is that? The one near me told me $125 for the key and programming. I told him to shove it and I will just be careful with the one key. I bought 2 more on Ebay for $10 and had them cut at the local locksmith for a few bucks. Now at least I can get into the Jeep with the doors locked and the hardtop on. Stealerships suck.
Does this actually work? If it does then I could be all set for the time being.
FireFighter's Jeep Club #84
I started out with nothing and still have most of it left.
Im getting tired of thinking...guess I'll do some wishful drinking.
MontyTJ02 is offline
post #12 of 39 Old 02-17-2008, 08:54 PM
Bigbob
Bigbob's Avatar
That was on my old PT Cruiser. Funny thing is, my son took his Neon in t6o the same place about the same time and they charged him $83.00 for the same service. Go figure. I did not have a key cut. They ordered a new key using my key code or VIN and programed it.
6 Speed, Hardtop
Bigbob is offline
post #13 of 39 Old 02-18-2008, 01:18 AM
sryan2k1
How did I do ??
Pretty good =) There is a little computer in the key that when power is applied (inductively, like the way a Sonicare toothbrush charges actually) emits a radio signal with it's unique fingerprint/ID. The security module in the ECU stores these unique IDs, not the other way around (the keys aren't programed for the vehicles, the vehicles are programed to remember specific transponder IDs)
Without two the ECU won't let you add another one, and unless you happen to have the $10,000 DRB-III module to reprogram the ECU, a dealer is going to have to do it.
Also the memory can be erased as many times as necessary, so it's 8 keys at any one time, not over a lifetime.
And yes if you jam the transponder close enough to the antenna (around the cylinder) you will be able to start it with any key that fits, since the other key will respond when the security module query's it.
sryan2k1 is offline
post #14 of 39 Old 02-18-2008, 07:36 AM
2jhanna
Originally Posted by sryan2k1 View Post
Pretty good =)
It should also be stated that if you do this, the key used to turn the cylinder should not be a transponder. If 2 keys respond, that will "confuse" the ECU.
You can have a standard $2.00 key cut to use on doors and start your Jeep. If you use double sided tape and mount the transponder's key top to the steering column, a standard key can be used.
You just lose the protection of the secure key feature.
jhanna
denton county, tx
2jhanna is offline
post #15 of 39 Old 02-18-2008, 08:46 AM
RUBtjICON
Does all new Jeeps have the sentry key ? I had both keys for my X model, but for the Rubi I only got one, and it is a copy.
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline
D30 Replacement Options? SuperWade2 TJ Wrangler Technical Forum 47 04-05-2009 05:09 PM
What are my options for fog light replacement? 05LjNj TJ Wrangler Technical Forum 12 10-12-2008 02:18 PM
top replacement- options paroxysym TJ Wrangler Technical Forum 3 03-15-2007 07:50 AM
Replacement Sentry Key TorxMonkey TJ Wrangler Technical Forum 16 10-30-2005 04:36 PM
AX5 replacement options. superjoe YJ Wrangler Technical Forum 4 06-27-2005 06:46 PM
