Seized lug nuts? - JeepForum.com
post #1 of 16 Old 07-06-2010, 07:31 AM Thread Starter
Mudbug1979
Seized lug nuts?
I was going to do an axle shaft swap this weekend, but I found that I have two lug nuts that are seized up on the bolts. I put an impact to them but nothing happened. I know if I put a lug wrench on them i will snap the bolts off my wheel spacers. Any suggestions on how to get them off without breaking them?:
Mudbug1979 is offline
post #2 of 16 Old 07-06-2010, 07:39 AM
greta
i had the same thing happen... ended up braking them and replacing them. wasnt too hard.
greta is offline
post #3 of 16 Old 07-06-2010, 07:43 AM
g4x4xgeoff
I took a nut breaker to mine. at some point one of my lug nuts got cross threaded, and when I took an impact to remove it, it spun itself out of the axle shaft, wearing down all the little threads. only way to remove it was the nut breaker.
Took me about a half hour to snap the nut, remove the tire, brake assy. and reinstall a new stud.
g4x4xgeoff is offline
post #4 of 16 Old 07-06-2010, 07:47 AM Thread Starter
Mudbug1979
I know it is easy to break off, I've had to do it before. I was looking for a way to do it so I wouldn't have to buy a new wheel spacer.
post #5 of 16 Old 07-06-2010, 07:49 AM
g4x4xgeoff
Why would breaking off a nut ruin the spacer? I replaced my stud because the Stud was stripped.
post #6 of 16 Old 07-06-2010, 07:51 AM
mdm
Farm Wheeler
Why would you need to buy a new spacer? You should be able to just replace the stud.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #7 of 16 Old 07-06-2010, 07:56 AM Thread Starter
Mudbug1979
I didn't think the studs were replacable on wheel spacers. learned something new.
post #8 of 16 Old 07-06-2010, 08:55 AM
Apex
Recon death squad
Apex's Avatar
I would sure hope they are replaceable..I'd never buy $100 wheelspacer that would need replaced if I stripped a stud.
Apex is offline
post #9 of 16 Old 07-06-2010, 09:42 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
One good thing I learned years ago is to apply antiseize to the stud and lug nut threads to prevent this very thing. I always use it and haven't had a seized nut since. I did recently have 4-5 seized nuts but they were on the used TJ I bought recently that didn't have antiseize on the wheel stud threads. I had to use a breaker bar to get the nuts off which of course snapped the studs.
Jerry Bransford is online now
post #10 of 16 Old 07-06-2010, 09:54 AM
Apex
Recon death squad
Apex's Avatar
One thing...DO NOT put a torch to anything.
EDIT: Here it is
http://www.youtube.com/user/Equipmen.../1/jBUVzgCHHuA
Apex is offline
post #11 of 16 Old 07-06-2010, 06:01 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
When using antiseize on the studs, reduce the torque of the lug nuts by 10-20%...
Knuckelhead is offline
post #12 of 16 Old 07-06-2010, 06:43 PM
Noxian
2011 JK Wrangler
you could try spraying them down with penetrating oil but it will most likely contaminate your brakes and you may need to replace them too.
Noxian is offline
post #13 of 16 Old 07-06-2010, 06:53 PM
demon67
simple really try hitting the socket with a hammer as you turn it Ive done that on every thing from cars too simitrucks works good
demon67 is offline
post #14 of 16 Old 07-06-2010, 08:12 PM
BlueFlame
BlueFlame's Avatar
Try a breaker bar. You can break bolts loose that an impact can't move. Thats why they call it a breaker bar...
Use a cheater pipe if you have to.
ALWAYS use a breaker bar to begin to loosen highly torqued nuts, then the impact to run them off. Same with torquing them, don't hammer them on with the impact, torque by hand. Both will saves time and potential other screw ups.
If you do snap the stud off, no big deal. Easy fix.
BlueFlame is offline
post #15 of 16 Old 07-06-2010, 10:30 PM
swampdweller126
2006 KJ Liberty
Craftsman sells a set of nut removers. They work but the nut will not be reusable.
swampdweller126 is offline
seized lug nuts , lug nuts , removal
2.5 Engine seized? NEED HELP spense33 YJ Wrangler Technical Forum 5 08-15-2009 07:25 PM
Tie-rod Seized Panici TJ Wrangler Technical Forum 11 09-02-2008 08:54 PM
Seized Cam Bolt Nut (Black_Jeep) TJ Wrangler Technical Forum 3 08-19-2008 05:09 PM
Spinning Nuts Driving Me Nuts Xenophage TJ Wrangler Technical Forum 2 03-16-2007 05:36 PM
Seized Tie Rod TheLiveSoundGuy TJ Wrangler Technical Forum 3 06-10-2006 07:48 PM
