Seeking the "collective wisdom" on lockers - JeepForum.com
post #1 of 7 Old 09-03-2002, 11:58 AM Thread Starter
moose
Have been on the list over a month now, and learned much!
After 12 years with my YJ, I am contemplating a new TJ. Fueled by various conversations on the list, I was all hyped about the Rubicon. Then, reality set in. I'll list my requirements & uses below - and leave it to all of you to tell me what I "really" need in the way of a new Jeep:) (FWIW - I DON'T want a Liberty:)
1) I DO NOT go off-road, at least not the way most of you crazy yahoos do!:):) Instead, I do lots of backroads, fire roads, and "improved" 2-track trails. My major concern is a) gravel/rock damage to undercarraige components d/t my high rate of speed, and b) hitting fairly large potholes at speed.
2) The new jeeper will be my daily ride, as well as a vehicle that will have many highway (60-70 mph) miles put on it.
3) I am planning a trip to Alaska next Summer (and the Trans Labrador Highway the following Summer.) I will be going all of the way to Prudhoe Bay on the Dalton "highway". There could be mucho deep mud &thawed permafrost along the way. There WILL be mucho gravel and rocks - which I take at a pretty good pace:) Also - I will also be putting on nearly 8k highway miles to get to & from Alaska!
As you can see - I will be using my Jeep as more of an "adventure tourer" than an off-road vehicle (the same way I use my BMW R1100GS morotcycle:) My questions/concerns are these -
*Do I really need a vehicle with locking diffs? With not really going OR, will they be that useful fording rivers, going through washed out, muddy roads, etc.? And - will they pose any problems in a vehicle as a daily driver, i.e., excessive wear/problems with constant turning & whatnot?
* Even with the 4-speed auto, I'm concerned about the 4.10 in the Rubicon. Am I correct, most of the other Wranglers (2003) will come with 3.73s?? A better choice for the daily stuff, as well as the highway miles to & from Alaska and Labrador?
Any other concerns, ideas, etc., that any of you guys can think of? And as much as I hate to ask this question - would a Liberty (with appropriate skid plates, etc.) actually be a better choice? (Please say NO:)
TIA - MUCHO!
jm
jm
moose is offline
post #2 of 7 Old 09-03-2002, 12:15 PM
Bob J
Bob J's Avatar
1984
Re: Seeking the "collective wisdom" on lockers
1) I DO NOT go off-road, at least not the way most of you crazy yahoos do! Instead, I do lots of backroads, fire roads, and "improved" 2-track trails. My major concern is a) gravel/rock damage to undercarraige components d/t my high rate of speed, and b) hitting fairly large potholes at speed.
skid plates and steel wheels with lots of rubber wrapped around them to protect them (big tires)
31"s on a TJ 4.0 w/ auto, no lift
3) I am planning a trip to Alaska next Summer (and the Trans Labrador Highway the following Summer.) I will be going all of the way to Prudhoe Bay on the Dalton "highway". There could be mucho deep mud &thawed permafrost along the way. There WILL be mucho gravel and rocks - which I take at a pretty good pace Also - I will also be putting on nearly 8k highway miles to get to & from Alaska!
Good 31" M/Ts, a front locker would be good too.
As you can see - I will be using my Jeep as more of an "adventure tourer" than an off-road vehicle (the same way I use my BMW R1100GS morotcycle My questions/concerns are these -
I don't need any of this, you can probably get away with crappy foreign pick-up. However you want to keep this longer, a front locker will be helpful, if you choose a more expensive route, selectable lockers would be perfect, when you turn them off, they don't affect the daily driver aspect at all. For cheaper a front auto-locker like the no-slip will be good, you will only know it's there in 4WD.
Stick with a Sport or Sahara, if you want to save some money, just get an '02
Any other concerns, ideas, etc., that any of you guys can think of? And as much as I hate to ask this question - would a Liberty (with appropriate skid plates, etc.) actually be a better choice? (Please say NO)
TIA - MUCHO!
jm
I've heard a Libby with ARBs front and rear can do many a wonderous thing
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #3 of 7 Old 09-03-2002, 12:24 PM
Parajeeper
Parajeeper's Avatar
No you do not need locking differentials if you are only going to be running backroads, fire roads, and "improved" 2-track trails.
The Rubicon may be overkill. A Sport or even the 4banger SE if you are concerned about gas mileage would be sufficient.
I do not think the liberty is a better choice for anybody. Get the 2003 or even try to get a deal on a 2002 Sport or SE with a hardtop. Depending on your tastes will be if you want the auto or stick. I prefer the auto. The 4banger stick gets the best gas mileage rating and should be fine for you applications. Get the Dana 44 rear though cause as we have all heard the " I only do minor trails" comments before, you willl soon be hit by the upgrade bug and will be glad you payed the extra 4-800 for the D44 rear end. As for the skid plates protecting the other side. GO and get yourself a skidrow oil pan skid plate for 225 (fits 97-2002 unsure about 2003 and be done with it. And SLOW down don't fly over potholes, any vehicle regardless of type will wear quicker by abusing it in this way. Yes the jeep will take it, but why do you want to do that?
Parajeeper is offline
post #4 of 7 Old 09-03-2002, 12:29 PM
'drack
Re: Re: Seeking the "collective wisdom" on lockers
And I've seen said Libby do these things . The only problem with the KJ is the weak design of the front axle housing. This is a problem and doesn't require hardcore wheeling to destroy. Not sure if the factory has dealt with the issue yet though. But it can be quite the capable little trail vehicle with room and comfort to boot.................no I'm not getting one .
Obviously I'd get a TJ, but I'm biased . If you're worried about space and comfort maybe a KJ is the answer. I use my TJ as a daily driver and am pleased with the ride(lifted with 33's none the less) and I find space for the wife, a two year old, and dog too .
Keith
'00 TJ with some stuff
'drack is offline
post #5 of 7 Old 09-03-2002, 12:54 PM
Bob J
Bob J's Avatar
1984
ah, about tops, I think I remember you saying you will be taking this back to warmer weather, in which case you might want to get dual tops, leave the softtop at home while you take your trip, it's better to get the top as an option, then pay full price for it later.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #6 of 7 Old 09-04-2002, 09:07 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
First, let me say I Love my TJ. That said, it may not be the best choice for you if you want a daily driver that occasionally sees some dirt roads. TJS have all the aerodynamic qualities of a brick )ie bad mileage and wind buffets can be bad). The ride isn't the softest around and every little bump can be felt and may cause you to move around on the road (short wheelbase at work). My wife isn't a fan of long drives (read trip to Alaska and back) in the TJ.
I have to agree with 'drack, the Liberty is a pretty capable vehicle. I saw two in action at the Jeep Jamboree in LA. They went everywhere that the stock TJs did and had leather seats! Ride smoother, handle better and better mileage. No I am not getting one either, but it would be my wife's choice (we almost bought one for her).
Take a bunch of test drives. And for a bit of blasphemy of this site: take a look at the Suburu Outback, all-wheel drive is awesome for dirt, snow, ice and rain.
HTH
Whybu1 is offline
post #7 of 7 Old 09-04-2002, 09:34 PM
saharajeepn
Pay now or pay later,get the Rubicon.Yes it might be a little OVERKILL for ya but you'll have everything you need but a winch.
2008 duramax ltz 5inch mbrp edge race evo
95 yj 5.3 60's f & r 4.56 44 boggers,can am outlander 800
saharajeepn is offline
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
Seeking your carllective wisdom kappaknight Wrangler General Discussion 0 06-18-2009 09:03 AM
Rubicon - lock in "4 high" Lockers... swamper TJ Wrangler Technical Forum 6 11-06-2008 07:32 AM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 01:24 PM
