see if anyone can make sense of this (alignment/control arm issues) - JeepForum.com
post #1 of 2 Old 07-14-2010, 08:32 PM Thread Starter
nate94gt
When i bought my jeep used it had a 3-4" lift, crappy adjustable LCAs in the front w/ stock UCAs.
I since replaced the upper UCAs w/ adjustable ones because i had a bad bushing in the stocker, so it would be a good time to get adjustable uppers. I then noticed that my left lower control arm mount that is on the frame was bent pretty good.
I pulled the front driveshaft at that point to lube up the slipyoke and check the ujoints. During that process i noticed that i could barely get the front ujoint out of the yoke because the axle was back too far (the jeep was on a lift w/ the suspension hanging). Well thats no good, its a snapped transfer case waiting to happen or some other expensive damage i would think. So i ordered up the adjustable lowers so i could move the axle forward a bit more to give the driveshaft some play while the suspension is drooped.
So today i got the adjustable LCAs installed. One mistake was NOT measuring my wheelbase before i began. Whoops. What i did do, was measure my old LCAs. they were at like 17" center to center. now i knew that was too short because of the lack of play in my front driveshaft. I extended them out to 18" before i installed them, giving me a place to start.
When i got finished, i measured the wheelbase to make sure that it was even on both sides. i adjusted it a tad and it came out to about 94" on both sides. that said, my left LCA was a bit longer than the drivers side to make up for the tweaked mount. I then adjusted the uppers to make sure the pinion angle was ok. i installed those at the same length.
I thought all was going to be well and took it out for a test drive. now the steering wheel is off center (is turned to the left while driving straight) and the jeep now pulls to the right. Why would that be? Should i just readjust the LCAs to make sure they are the same length? If they were the same length, the wheelbase would be off a bit (half an inch i believe), so what in the alignment would make up for the pulling to the right? Should i also make the left UCA arm longer than the right UCA?
Before i did all this, the tires appeared to wear even, the jeep did not pull, and the steering wheel was centered. I do ASSUME, however, that the wheelbase was different on both sides.
yes, it would be best to get new CA mounts, but if i was going to get new mounts, then at that point, if you are going to hack off the old mounts, why replace them w/ another mount in the same location? it would be best just get a long arm set up, so then im spending a whole lot more than intended
this post is kind of out of order a bit, i just starting going as i thought of stuff
nate94gt is offline
post #2 of 2 Old 07-14-2010, 08:54 PM
Fropleyqk
Fropleyqk's Avatar
Unless something else is out of whack, all of your problems are stemming from the bent CA bracket. I see your logic of going from new mounts>LA kit but honestly, unless you have the money, that doesnt make sense. Sure a LA kit would get rid of the stock bracket but is that what you want to do? A new CA bracket is pretty cheap. I say hack off the bent one and melt a new one on then call it a day. If you leave the bent one, youre going to be chasing this issue forever. Fix it right and call it done.
Fropleyqk is offline
lca , uca , adjustable , control arm , alignment , steering , steering system , pinion angle , uneven , advice , help , suggestions
Replaced u-joint, now I get better gas mileage? khill8469 TJ Wrangler Technical Forum 4 06-30-2010 08:05 PM
2000 4.0 issues, does this make sense? BarryBum TJ Wrangler Technical Forum 24 02-07-2010 01:49 PM
does it make sense to do this? paroxysym TJ Wrangler Technical Forum 5 11-02-2005 03:24 PM
does this make sense? paroxysym TJ Wrangler Technical Forum 4 10-17-2005 09:41 AM
Does this make sense? smunns TJ Wrangler Technical Forum 14 05-27-2002 05:26 PM
