Seatbelt Mount Question - JeepForum.com
post #1 of 7 Old 07-18-2013, 01:42 PM Thread Starter
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
I'll try to explain this as best as I can without pics...
I've long since removed my rollbar covers and I've been running my seatbelt as it came from the factory with the black plastic covering over the channel it mounts in. I was wondering if I could remove the channel altogether and just mount the seatbelt into the bung at the top (currently the bolt running through there holds the top of the mounting channel in place).
Would this be safe enough or is the channel there to serve as multiple mounting points?
Would I be better off (safety wise) just removing the gold female clips that the plastic cover mounts to and leave the seatbelt mounted through the middle hole (in the channel)?
If this isn't making sense I'll try to dig up some pics.
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #2 of 7 Old 07-18-2013, 09:37 PM Thread Starter
EugeneTheTJ
Tar Heel
Bump...no one's done this?
2016 TJ of the Year
Founder,
post #3 of 7 Old 07-18-2013, 09:41 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
This is actually something I have been wanting to do for a long time. I'm curious as well.
Mail crawling.
MisfitSeven is offline
post #4 of 7 Old 07-19-2013, 03:20 PM
JEK3
JEK3's Avatar
If you have the adjuster in the top position, the top bolt would see 80-90% of the force in a collision. Since it's safety equipment, there is probably a safety margin of 200-300% built in. Based on these, I would go for it and mount it in the top hole. I can't tell you to do this, though, as I wouldn't want the liability if it doesn't work.
JEK3 is offline
post #5 of 7 Old 07-19-2013, 03:58 PM Thread Starter
EugeneTheTJ
Tar Heel
I sent the resident expert a message on the subject. Hopefully he'll jump in here when he gets a chance.
2016 TJ of the Year
Founder,
post #6 of 7 Old 07-21-2013, 04:49 PM Thread Starter
EugeneTheTJ
Tar Heel
Bump for answers
2016 TJ of the Year
Founder,
post #7 of 7 Old 08-09-2013, 01:01 PM
rkwfxd
I removed my plastic stuff and mounted my belt in the top hole. Seems safe enough but I have not crashed and I hope not to.
rkwfxd is offline
