seatbelt light stays on - JeepForum.com
post #1 of 7 Old 03-16-2006, 02:06 PM Thread Starter
mahanjeep
on my 97 tj even if both seatbelts are fastened the light stays on, any suggestions on what i need to buy? thanks for your help, josh
mahanjeep is offline
post #2 of 7 Old 03-16-2006, 02:08 PM
Rocky529
Rocky529's Avatar
Check the connection under your seat.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 7 Old 03-16-2006, 02:43 PM Thread Starter
mahanjeep
it is connected
post #4 of 7 Old 03-16-2006, 04:32 PM
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
Take out the bulb
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline
post #5 of 7 Old 03-16-2006, 05:10 PM
criminal_mind
Double check your connection. Unplug it then plug it back in. When unplugged make sure none of the connectors are bent/missing.
HTH
criminal_mind is offline
post #6 of 7 Old 03-16-2006, 05:14 PM
amiller
I couldn't stand the light so I unplugged the wire under the seat. Problem solved. I suppose it would be just as easy to wear the seatbelt, but I cant stand them. Good luck on your fix.
amiller is offline
post #7 of 7 Old 03-16-2006, 06:26 PM
06slvrrubi
06slvrrubi's Avatar
I always wear my belt, however, the day after I got my TJ, I unplugged that connector under the seat. I don't like warning lights for things that are so common sense. I would say that if you unplug that connector under the seat, the light should go out and stay out (other than during the bulb check when you start your Jeep). Give it a try.
1995 YJ Rio Grande
06slvrrubi is offline
Air Bag light stays on! CoastalKid TJ Wrangler Technical Forum 9 09-01-2010 09:29 AM
Cab Light stays on six-gun TJ Wrangler Technical Forum 9 01-20-2010 10:08 AM
Shifter Light..Seatbelt Light..argg...Turn Off.... jmiller TJ Wrangler Technical Forum 17 07-12-2005 02:47 PM
4wd light stays on when in 2wd chriss YJ Wrangler Technical Forum 1 05-10-2005 03:29 PM
4wd light stays on Ex CCS Racer YJ Wrangler Technical Forum 4 08-18-2003 06:53 PM
