Seat swapping questions - JeepForum.com
post #1 of 11 Old 07-04-2010, 12:40 PM Thread Starter
CB3
I'm going to swap front seats from my 2006 LJ with a forum member who has an older model TJ. I have the new style seats and he has the old style.
The reason we want to do this is that seats are like shoes, they either fit your body or they don't. If they don't, back pain results.
The old style seats fit me perfectly. The new style fit him perfectly.
However, all the above is regarding swapping front seats, which we've been told are compatible for bolt pattern and mounting in Jeep.
We also want to swap our rear seats so that the upholstery colors/patterns of our front and rear seats will match.
Will our rear seats be compatible for a swap? i.e. - will the seat tracks be the same, and fit rear seat?
CB3 is offline
post #2 of 11 Old 07-04-2010, 12:45 PM
BYuen
BYuen's Avatar
I know the front seats will be a direct swap, but I'm not sure about the rear seats. I know the rear seats in the later models are different than the ones found in earlier models, but I'm not sure if the differences would affect the fit between the two.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 11 Old 07-04-2010, 01:14 PM
dbx11
I swapped mine out
I have a 97tj that had the old style round type. I swapped both front seats and kept the brackets/sliders. Simply unbolt the seats 4 screws IIRC. The rear requires the bracketry to be swapped over. The front two brackets will bolt right up to where the old hardware was removed from the older model jeep. The rear brackets for the newer seat will require some drilling so remember to measure and remeasure before you drill. This worked for me hope you find this helpful.
dbx11 is offline
post #4 of 11 Old 07-04-2010, 01:19 PM Thread Starter
CB3
I'm confused by your reference to front brackets and rear brackets. Does that mean front brackets of front or rear seat? Does it mean all brackets of front seat? Same confusions about "rear brackets".
Please clarify.
CB3 is offline
post #5 of 11 Old 07-04-2010, 01:21 PM Thread Starter
CB3
Front Seats: How to swap? Instructions please.
Rear Seats: How to swap? Instructions please.
Note: It's the front seats we need to swap to stop our mutual back pain.
We don't need to swap rear seats, though we will if it's not to much trouble to swap rear seats.
CB3 is offline
post #6 of 11 Old 07-05-2010, 11:49 AM
dbx11
The front seats and brakets swapped out easily by unbolting the four bolts that hold them to the floor. You will have to switch the electrical connector as well if you want that awesome fasten your seatbelt chime! As for the rear seat conversion it is a bit of a challenge but can be done because I did it! I removed the old rear seat and the four brackets that held it to the jeep. Next I put the front brackets in place using the existing holes.( Take note on how they were mounted because they may be put in backwards). After the front brackets are in the seat will lock onto them but will not stay in sitting position so put it in the jeep and lock it up to the front brackets and hold into the sitting position so you can mock up the two rear brackets. These brackets will require drilling 4 holes so make sure you check twice before you drill. I used a bit that was a hair small for the bolt to grip onto because I could not access the nuts with the fuel tank in the way. Well that's all I can remember so good luck and if you have any more questions just ask.
dbx11 is offline
post #7 of 11 Old 07-05-2010, 01:32 PM Thread Starter
CB3
Thanks everyone, especially dbx11. I'll just swap front seats since that's easy. It's all I care about since I plan to add black water proof seat covers.
The other fellow might want to swap rear seats to keep matching upolstery, but if so, I'll let him work out the rear seat stuff.
CB3 is offline
post #8 of 11 Old 07-06-2010, 07:09 AM
dbx11
Your welcome
Enjoy your new seats
dbx11 is offline
post #9 of 11 Old 07-10-2010, 06:53 PM Thread Starter
CB3
I will, thanks! This sort of thing is what makes me love this forum. Parts swapping, etc. Advise is nice, parts are smart.
The guy I'm trading with is not a forum member, but I did meet him through a forum member. I think he'll probably become a new member soon.
CB3 is offline
post #10 of 11 Old 07-10-2010, 08:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Given your disability and ride height issues, you may want to temporarily bolt in the older seat first before completing the trade. The pre-03 seats are 1" or so higher than the later versions.
In order to stop my back from hurting, I did a seat riser on the later seats to make them the same height as the earlier seats and the problem went away.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #11 of 11 Old 07-13-2010, 09:43 PM Thread Starter
CB3
Thanks for the advice. I'll do a temporary tryout of the older seat style to make sure I can still get in Jeep.
My main issue getting in is getting my right foot over the door sill. So the extra seat height might not be an issue for me, but it's defineately a good idea to test it out before committing to it. Thanks for the advice.
CB3 is offline
back , bolt in , compatible , front , rear , seat , swap
Swapping Drivers seat for passenger seat trevsbmw YJ Wrangler Technical Forum 8 05-22-2009 05:38 PM
Seat swapping BassWrangler YJ Wrangler Technical Forum 15 03-05-2009 12:09 PM
Swapping a rear seat J33Pyj YJ Wrangler Technical Forum 4 03-05-2008 08:06 AM
Seat swapping Cts6867 YJ Wrangler Technical Forum 1 09-25-2007 06:46 PM
Seat Swapping Heep TJ Wrangler Technical Forum 1 04-06-2007 10:46 AM
